Hello all,
I have been trying to get an ELM327 talking to my car, so far it finds just the engine ECU. looking at the OBD connections it seems that my C5s OBD does not match the ELM connections. has anyone please got the pinouts for my C5X7 model . I have found one for 2009 at:
viewtopic.php?p=535348#p535348
but just want to double check before I start changing the ELM wiring.
Kind regards
Steve
C5 X7 2013 OBD SOCKET
- x 6961
Re: C5 X7 2013 OBD SOCKET
You should also be aware that basic OBD II readers won't be able to read all the fault codes for these vehicles, like most modern vehicles, as there are hundreds of constructor fault codes that go beyond the basic OBDII cdes, plus they often do not provide the full 7 alphanumeric code only the first 5, which makes i more difficult to pin down issues.
stephenhollis02
Hi Marc,
thank you but yes, I am aware of the shortcomings. Could you please confirm the ODB socket wiring for me?
cheers
cheers
- x 6961
16 way Central Diagnostic Socket
| Terminal | signal |
| 1 | +APC |
| 2 | Not connected |
| 3 | DIAGNOSTIC CAN (High) |
| 4 | Tester earth |
| 5 | Signal earth |
| 6 | CAN (High) |
| 7 | Not connected |
| 8 | DIAGNOSTIC CAN (Low) |
| 9 | Not connected |
| 10 | Not connected |
| 11 | Not connected |
| 12 | Not connected |
| 13 | Not connected |
| 14 | CAN (Low) |
| 15 | Not connected |
| 16 | Tester Permanent + |
cit-rotti
- x 77
Serious and complete diagnosis for a C5 X7 is only possible with the Diagbox. Depending on the equipment, the vehicle has 25-30 control units.
Cheap products usually only recognise the injection ECU. Better diagnostic tools then recognise 5-7 ECUs - but they all lack depth.
If that's enough for you - OK.
Wolfgang
Wolfgang
stephenhollis02
thanks for the input. As it only has 2 CAN busses it will be interesting to see what it can connect to. I will put some feedback on here once I have done more on this, hope it will help others trying the same.
Steve
Steve
