sar77
- x 4
Hello,
2014 Citroen C4 Picasso blueHdi 2.0 110 kW. VIN: VF7**************[VIN obfuscated, can be read by forum staff].
Could I have the OEM codes and parts diagram for the capacitor (power accumulator) and voltage retaining device.
Thank you in advance.
Sarunas
Together we can do more
- x 6963
(1) Ultracapacitor, part: 9852039780, £211.68
(3) Converter Unit, part: 9818459680, £798.67
Friendly warning about discharging old capacitors before removal!
sar77
- x 4
Thanks Marc,
The prices make me abandon the idea of restoring the Start/Stop system. I don't regret it at all.
Sarunas
OnlineMattBLancs
- x 2263
Hi,
A few queries for the Blue 308 SW
Mine has the touch screen dab radio / sat nav / Bluetooth etc set, but no CD player. Can you confirm part number for the CD player please?
I've picked up hopefully the correct fascia (listed as part number 96777664ZD ) so it's just the drive sat behind I need to confirm.
If there's a diagram showing any cabling (fingers crossed I do not need anything additional to link this to the main radio unit, sat behind the touchscreen) that would also be useful too.
Front right driver's side wheel arch inner plastic liner part number please and if the part number shows enough detail to confirm if it should have a grille in it that'd be useful. Current item is (very tired and) solid, but I've seen some with a grille in it and the intercooler is immediately the other side so would be logical for hot air to come out said grille!
Matt
Matt
rrc102
Hi all,
2015 C4 Grand Piscasso 2.0HDI
Could I grab the part number and diagram for the offside driveshaft please? If you could confirm the gearbox code fitted as well that would be great. Many thanks.
- x 6963
(2) OEM New Driveshaft (Right), part: 9804894080, £536.23
Cheaper Citroen Alternative Driveshaft (Right), part: 1609609080, £321.95
(1) New Gearbox, CP 19x70, Marking MB33, part: 9820672880, £7,722.84
Exchange Gearbox, part: 1618101680, £3,741.29
2 Component Pro Kit for Clutch (Required for exchange Gearbox above), part: 1616517180, £631.40
Sloppysod
- x 381
Hi Marc, Could please download a build sheet for my car?.
Vin - VR7**************[VIN obfuscated, can be read by forum staff] -
Thank you
Thank you
Stu
- x 6963
Here you go Stu:
| Vehicle Characteristics | |
| Vehicle family | C5 X (E43 EIC) |
| AS/RP N° | 16771 VD 1 0077 |
| Warranty Start Date | 22/03/2023 |
| Engine serial number | 10 FKBJ 2953009 |
| BER | e9*2018/858*11066*03 |
| P4A | 9839622299 |
| General Information | |
| PRODUCT TYPE | PASSENGER CAR |
| COMMERCIAL MARQUE/COMPONENT TYPE | CITROEN |
| VEHICLE FAMILY | C5 X (E43 EIC) |
| SILHOUETTE | CROSSOVER |
| TRIM LEVEL | UPPER MEDIUM |
| ENGINE | EP6FADTXHP 1.6L PETROL |
| TRANSMISSION | 4X2 8-SPEED AUTOMATIC HYBRID |
| PAINT TYPE | PAINTED METALLIC EXT TRIM TYPE |
| BODY COLOUR | PLATINUM GREY PAINT |
| INTERIOR TRIM TYPE | PALOMA "LR" LEATHER |
| UPHOLSTERY COLOUR | "FX" |
| GEARBOX (CHARACTERISTICS) | EATNG8 |
| CONVERSION GUIDANCE | WITHOUT CONVERSION |
| DEFINITION TO FOLLOW | INITIALE RANGE |
| ENGINE (TYPE) | EP TYPE ENGINE |
| ROOF (EXT. ASPECT) | BODY COLOUR ROOF |
| Fuel Supply-Engine | |
| FUEL | UNLEADED PETROL 95 QUALITY A/B/E/E+ |
| EMISSIONS STANDARD (ENGINE) | EURO 6.3 ENGINE EMISSION CONTROL |
| CAPACITY | 1600 CM3 |
| FUEL TANK INSULATION | WITHOUT FUEL TANK INSULATION |
| COOLING MOTOR | RADIATOR EP28 28DM2 BRAZED ALUMINIUM |
| CRANKCASE GAS CIRCUIT HEATING | W/O HEATER CASING GAS CIRCUIT |
| EOBD SELF-DIAGNOSIS SYSTEM | WITH "OBD" AUTO-DIAGNOSTICS |
| DEVICE (ANTIPOLLUTION) | WITHOUT ANTI-POLLUTION DEVICE |
| VEHICLE TECHNICAL DEPOLLUTION | EURO 6.3 VEHICLE TECHNICAL EMISSION CONTROL |
| FAN | VARIABLE SPEED FAN 200W AERO DYNAMIC FLAP |
| INJECTION ASSOCIATED VARIANT | MOUNTING BOSCH |
| DRIVE TRAIN | PHEV DRIVE TRAIN |
| TANK FILTER | RESERVOIR FILTER INTERIOR |
| STOP AND START | WITHOUT STOP AND START |
| Gearbox Transmission | |
| FINAL DRIVE RATIO | FINAL DRIVE RATIO 15 X 58 |
| WHEEL STYLE | 19-INCH STYLE WHEEL |
| CLUTCH | WITHOUT CLUTCH |
| RIM/TYRE SIZE | 19 INCH TYRE FIT |
| TYRE (SIZE, TYPE) | 205/55 R19 97V TYRE |
| DRIVING WHEELS | 2 DRIVEN WHEELS |
| WHEELS FITTED | WHEELS FITTED 7 J19 RIM OFFSET 41 |
| WHEEL (TYPE) | ALLOY WHEEL ASSEMBLY 1 |
| GEARBOX TYPE | GEARBOX TYPE EATN8 |
| Suspension-Steering-Brakes | |
| BRAKING ASSISTANCE IN REVERSE GEAR | COLLISION WARNING - RCTA |
| REAR ANTI-ROLL BAR | REAR ANTI-ROLL BAR STIFFNESS 25000 NM/RAD REINFORCED |
| FRONT ANTI-ROLL BAR | FR ANTI-ROLL BAR STIFFNESS 30000 NM/RAD |
| BRAKE TYPE | VENTILATED FRONT DISCS/REAR DISCS |
| SUSPENSION | NORMAL SUSPENSION |
| SUSPENSION (ARCHITECTURE TYPE) | METAL SUSPENSION |
| DYNAMIC STABILITY CONTROL SYSTEM | ELECTRONIC STABILITY PROGRAM |
| STEERING (OPERATION) | HIGH POWER DOUBLE PINION ELECTRIC POWER STEERING |
| PEDAL BRACKET (TYPE) | PEDAL ALUMINIUM |
| Body Fittings | |
| TOWBAR | WITHOUT TOWBAR |
| SIDE MOULDINGS (DIMENSION) | WIDE SIDE PROTECTORS + SIDE SILL |
| WHEEL EMBELLISHER (STYLE) | BLACK CENTRE CAPS+BLACK BOLTS DESIGN |
| ADDITIONAL SHIELD (UNDER ENGINE) | W/O ENGINE UNDERSHELDING |
| EXT. REARVIEW MIRROR COMP. FUNCTION | DRIVER ELEC FOLDING+PASSENGER+DIODE+REVERSE +MEMORY |
| EXHAUST TAILPIPE TRIM | CHROME EXHAUST OUTLET TRIM |
| ENGINE BAY SOUNDPROOFING | BULKHEAD SOUNDPROOFING +RH+ISOVAC+WHEEL ARCH |
| WINDSCREEN GLASS (TYPE) | STANDARD WINDSCREEN GLASS |
| WINDSCREEN WIPER | FRONT WIPER BLADE WITH RAIN SENSOR |
| ROOF GLASS | WITHOUT ROOF WINDOW |
| BUMPER | CHROME + BODY COLOUR FRONT/REAR BUMPER |
| LUGGAGE RACK | WITHOUT ROOF BARS |
| FRONT FOGLAMP | LED FOG LAMPS + CORNERING LAMP |
| PANORAMIC VISUAL AID | DIGITAL PANORAMIC VISUAL ASSISTANCE |
| SPARE WHEEL | WITHOUT SPARE WHEEL |
| SUN ROOF | WITHOUT SUN ROOF |
| GLASS (APPEARANCE) | TINTED + DARK-TINTED RR WINDOW GLASS |
| HANDS FREE ACCESS AND STARTING | FRONT ACCESS+BOOT+CONTACTLESS STARTING |
| Interior Fittings | |
| ANTI-THEFT ALARM | VOLUME + PERIMETER + LIFT |
| FRONT HEAD RESTRAINT | 4-WAY ADJUSTABLE FRONT HEAD RESTRAINT |
| REAR SEAT | MONOCHROME REAR SEAT FX+FOLDING 40/20/40 SEAT BACK |
| BLIND SPOT DETECTION | BLIND SPOT MONITORING + LANE CHANGE ASSIST |
| REAR SEAT ARMREST | WITH REAR SEAT ARMREST |
| INTERIOR ALARM | 3-SENSOR INTERIOR ALARM |
| RADIO TELEPHONE | 2 SMARTPHONES |
| LUGGAGE COVER | SCREEN |
| REAR SEATBELT | 3 REEL 3 PT REAR SAFE BELT + UNBUKLED WARNING |
| FRONT SEATBELT | REEL+FASTENING ALARM+CONSTANT PASSENGER/ACTIVE DRIVER FORCE LIMITER |
| CLIMATE (AMBIENT TEMP) | HOT OR WIDER TEMPERATE COUNTRY |
| AIR CONDITIONING | WITH HEATER MATRIX+ADDITIONAL OUTLET |
| CHILD LOCK | ELECTRIC REAR CHILD LOCK |
| SPEED GRADUATIONS | SPEED GRADUATION IN MPH |
| GRAB HANDLES | FRONT + REAR + RETRACTABLE HANDLES |
| CONSOLE | LONG CONSOLE + REAR AIR DUCT |
| DRIVING POSITION | RIGHT HAND DRIVE |
| MIRROR LINK | WITH MIRROR LINK |
| LOAD SPACE LIGHTING | LED GLOVE BOX LIGHTING |
| BOOT AND LOAD SPACE LIGHTING | BOOT + LOADING VOLUME LED AUTO LIGHTING CONTROL |
| DASHBOARD EQUIPMENT | BLACK STRIP+WOOD FILM DECOR |
| INSTRUMENT PANEL (CHARACTERISTICS) | INSTRUMENT PANEL BLACK BACKGROUND WITH MATRIX |
| LOUDSPEAKER | MOUNTING 2 FRONT LOUDSPEAKERS + 2 FRONT TWEETERS |
| ADDITIONAL BLOWER | WITHOUT ADDITIONAL PULSE |
| POLLEN FILTER | WITH+ACTIVATED CHARCOAL+FINE PARTICLE FILTER+GAS |
| LANE KEEPING MANAGEMENT ASSISTANCE | TRAJECTORY CONTROL ASSISTANCE/LANE POSITIONING ASSIST (LPA) LANE CENTRING |
| FRONT PASSENGER SEAT HEIGHT CONTROL | FR PASSENGER SEAT HEIGHT ADJUSTER ELECTRIC HEIGHT ADJUSTMENT |
| DRIVER SEAT CONTROL | DRIVER’S SEAT WITH MEMORY CONTROL+CUSHION FRONT ADJUSTMENT |
| FRONT PASSENGER SEAT CONTROL | ELECTRIC FRONT PASSENGER SEAT CONTROL |
| DRIVER SEAT ADJUSTMENT | DRIVER’S SEAT TILT BACK ELECTROPN LUMBAR SUPPORT |
| FRONT PASSENGER SEAT ADJUSTMENT | PASSENGER ELECTROPNEUMATIC LUMBAR ADJUSTMENT |
| STOWAGE BIN | STORAGE BOX WITHOUT COOLING |
| SATELLITE NAVIGATION SYSTEM | CONNECTABLE NAVIGATION SYSTEM |
| HEADLAMP BULBS | ECO LED |
| TRAFFIC INFORMATION READER | LKA STRUCTURAL EDGE |
| DISPLAY | 12-INCH COLOUR HD TOUCHSCREEN DISPLAY |
| COURTESY MIRROR | DRIVER+PASSENGER CONCEALABLE MIRROR WITH LED LIGHTING |
| FOOTREST | WITHOUT FOOTREST |
| CUSHION PADDING | PADDING WITH PASSENGER DETECTION PAD |
| FITTING REAR HEAD RESTRAINT | MOUNT 3 REAR HEAD-REST |
| HEATING ELEMENT | DRIVER + R1 PASSENGER HEATED SEAT |
| FRONT LATERAL AIRBAG | FR CHEST/PELVIS SIDE AIRBAG+INT+FR/RR CURTAIN |
| FOOTWELL LIGHTING | FOOTWELL LIGHTING WITH LED |
| AIRBAG DEACTIVATION | MANUAL AIRBAG DEACTIVATION |
| HEADLAMP HEIGHT ADJUSTER | REMOTE MANUAL HEADLAMP ADJUSTMENT |
| WIFI | WITHOUT WIFI |
| STORAGE (DRIVING POSITION) | STORAGE COMPARTMENT BRAKED OPENING |
| RADIO RECEIVER | ANALOGUE + DAB RADIO RECEIVER |
| REFRIGERATION | AUTOMATIC AIR CONDITIONING |
| CRUISE CONTROL | ACC3 DECEL0 + ACCEL0 |
| DRIVER’S SEAT HEIGHT CONTROL | ELECTRIC CONTRL DRIVERS HEIGHT ADJ |
| INTERIOR REAR VIEW MIRROR | FRAMELESS INTERIOR ELECTROCHROMATIC MIRROR |
| AIR CON./TEMPERATURE REGULATION | AUTOMATIC AIR CONDITIONNED BI-ZONE |
| STORAGE (OTHERS) | PLAIN STORAGE POCKET |
| LOAD SPACE STORAGE | BOOT LATERAL STRAP + NET |
| REAR SEAT PADDING | WITHOUT RR PASSENGER DETECTION |
| TUNER RADIO | DUAL RADIO TUNER |
| OBSTACLE DETECTION SYSTEM | FRONT/REAR RADAR OBSTACLE DETECTOR + TRAJECTORY |
| FLOOR MAT | FR + RR MATS |
| RADIO FREQUENCY | RADIO FREQUENCY AMT6_FMT4-50-DIAFTAPSTMC_DABT1 |
| LOCKING CONTROL | CENTRAL DEADLOCKING + AUTOMATIC LOCKING |
| STEERING WHEEL | FULL FLOWER LEATHER ST WHEEL |
| SEATING ASSOCIATED VARIANT | LOWER SEAT ASSOCIATED VARIANT |
| DRIVER’S KNEE AIRBAG | WITHOUT DRIVER’S KNEE AIRBAG |
| AUDIO PACK AUXILIARY SOCKET | AUXILIARY SOCKET AUDIO PACK 2 USB TYPE C |
| TELEMATIC UNIT | INDEPENDENT TELEMATIC UNIT |
| Electrical | |
| ALTERNATOR | ISTT60 |
| BATTERY | L3 760 70AH EFBC 760 BATTERY BECOMES EFBC |
| STARTER MOTOR | WITHOUT STARTER MOTOR |
| CEN. LOCKING REM CONTROL FREQUENCY | LOCKING REMOTE CONTROL FREQUENCY 433.92 MHZ HETERODYNE |
| ELECTRICAL EQUIPMENT (SUPPLY) | LEOCH BATTERY |
| BATTERY CHARGER | SINGLE-PHASE 7 KW ON-BOARD CHARGER |
| MULTIPLEXING | NEA R1 |
| ELECTRIC VEHICLE CHARGING PLUG | WITHOUT VEHICLE LOAD RECOGNITION |
| BATTERY CHARGE MEASUREMENT | WITH BATTERY CHARGE MEASUREMENT |
| LIGHTING OF LAMPS | AUTOMATIC SWITCHING ON OF THE LIGHTS+AUTOMATIC SWITCHING |
| Component Manufacturers | |
| Miscellaneous | |
| SPECIAL SPECIFICATION | STANDARD |
| MODIF. DURING MODEL YEAR | WITHOUT MINOR MODIFICATIONS |
| CONDENSER (SPECIFICATIONS) | CONDENSER 23,5DM2 THICKNESS 16 |
| ATMOSPHERIC CONDITIONS | NORMAL ATMOSPHERE |
| VIN PLATE | EUROPEAN UNION CONSTRUCTOR’S PLATE + NRE |
| AIR CONDITIONING PIPES | STANDARD AIR CONDITIONING PIPES |
| RADIO HEADPHONE SOCKET | DOUBLE ACCESSORY SOCKET |
| TRAFFIC SIDE | DRIVING ON THE LEFT-HAND SIDE |
| SIDE IMPACTS | UPPER REINFORCED SIDE IMPACT PROTECTORS |
| REFRIGERANT | AIRCON FLUID 1234 YF |
| EMERGENCY EQUIPMENT | PUNCTURE REPAIR KIT |
| SURFACE CONDITIONS | GOOD TERRAIN |
danlat1415
- x 24
Please could you confirm the part number for front drop link for VIN - VF7**************[VIN obfuscated, can be read by forum staff]
- x 6963
(2) Anti Roll Bar Rod (Drop Link):
OEM Original, parts 9844264780 & 9817224280 (Nut) , £45.96, & £2.14
Cheaper PSA Part: 1679755380, £20.72
OnlineMattBLancs
- x 2263
- x 6963
Only just picked this up via the parts thread Matt (always best to request parts there so they're not missed anywhere else).
As for CD, took me a while as there is no CD specified in parts for your vehicle, however I can confirm the Fascia part is correct and also the harness will be needed: So yes you need a specific harness to connect this to the main unit and of course it will need telecoding in the BSI. They deemed these not necessary, with Audio Streaming via Bluetooth and the ability to play media via USB. Please also note that connecting a CD will not allow copying of media to the internal 'Jukebox' storage according to info I have.
CD Harness for SMEG units, part: 6571QY, £78.13
The CD is not coming up against your vehicle, and the only one I can see that is compatible with the electronic architecture and build date is part: 1629118180, £328.02
Wheel Arch
(11) Right Wheel Housing Mudguard, part: 9819974080, £128.51
Wheel Arch
Micko
Can i get the number for the bolt thats holds the joint/yoke that connect the steering colum with the steering rack.
OnlineMattBLancs
- x 2263
Sorry Marc, it is on the parts thread, just a bit further up (a few other queries came in directly after mine which have been answered, hence my cheeky post as I reckoned I'd got lost in the noise somewhatGiveMeABreak wrote: 05 Feb 2025, 10:21 Only just picked this up via the parts thread Matt (always best to request parts there so they're not missed anywhere else).
Thanks for the comprehensive answers. Bit confused the fascia is correct (which is the one with a CD shaped hole in it!) but no CD drive coming up, very strange!
Not sure I've got the internal jukebox, or else I'm feeling daft not noticing it if so!?
Will get digging for lead and drive.
Wheel arch liner image is spot on - number 18 is the grille I tried to describe. Current liner has a removal panel in same spot, but it's solid!
As said intercooler is ahead of it so a route for airflow seems eminently sensible. More digging for me!
Thanks again
GORAX
- x 14
Hi everybody,
I need part number for gearbox oil seal and drain cap seal.
GOOGLE TRANSLATE
