sar77
x 4
Unread post by sar77 »
Hello,
2014 Citroen C4 Picasso blueHdi 2.0 110 kW. VIN: VF7**************[VIN obfuscated, can be read by forum staff].
Could I have the OEM codes and parts diagram for the capacitor (power accumulator) and voltage retaining device.
Thank you in advance.
Sarunas
Together we can do more
x 6950
(1) Ultracapacitor, part: 9852039780, £211.68
(3) Converter Unit, part: 9818459680, £798.67
Friendly warning about discharging old capacitors before removal!
sar77
x 4
Thanks Marc,
The prices make me abandon the idea of restoring the Start/Stop system. I don't regret it at all.
Sarunas
x 2367
Unread post by MattBLancs »
Hi,
A few queries for the Blue 308 SW
Mine has the touch screen dab radio / sat nav / Bluetooth etc set, but no CD player. Can you confirm part number for the CD player please?
I've picked up hopefully the correct fascia (listed as part number 96777664ZD ) so it's just the drive sat behind I need to confirm.
If there's a diagram showing any cabling (fingers crossed I do not need anything additional to link this to the main radio unit, sat behind the touchscreen) that would also be useful too.
Front right driver's side wheel arch inner plastic liner part number please and if the part number shows enough detail to confirm if it should have a grille in it that'd be useful. Current item is (very tired and) solid, but I've seen some with a grille in it and the intercooler is immediately the other side so would be logical for hot air to come out said grille!
Matt
rrc102
Unread post by rrc102 »
Hi all,
2015 C4 Grand Piscasso 2.0HDI
Could I grab the part number and diagram for the offside driveshaft please? If you could confirm the gearbox code fitted as well that would be great. Many thanks.
x 6950
(2) OEM New Driveshaft (Right), part: 9804894080, £536.23
Cheaper Citroen Alternative Driveshaft (Right), part: 1609609080, £321.95
(1) New Gearbox, CP 19x70, Marking MB33, part: 9820672880, £7,722.84
Exchange Gearbox, part: 1618101680, £3,741.29
2 Component Pro Kit for Clutch (Required for exchange Gearbox above), part: 1616517180, £631.40
Sloppysod
x 400
Unread post by Sloppysod »
Hi Marc, Could please download a build sheet for my car?.
Vin - VR7**************[VIN obfuscated, can be read by forum staff] -
Thank you
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
x 6950
Here you go Stu:
Vehicle Characteristics
Vehicle familyC5 X (E43 EIC)
AS/RP N°16771 VD 1 0077
Warranty Start Date22/03/2023
Engine serial number10 FKBJ 2953009
BERe9*2018/858*11066*03
P4A9839622299
General Information
PRODUCT TYPEPASSENGER CAR
COMMERCIAL MARQUE/COMPONENT TYPECITROEN
VEHICLE FAMILYC5 X (E43 EIC)
SILHOUETTECROSSOVER
TRIM LEVELUPPER MEDIUM
ENGINEEP6FADTXHP 1.6L PETROL
TRANSMISSION4X2 8-SPEED AUTOMATIC HYBRID
PAINT TYPEPAINTED METALLIC EXT TRIM TYPE
BODY COLOURPLATINUM GREY PAINT
INTERIOR TRIM TYPEPALOMA "LR" LEATHER
UPHOLSTERY COLOUR"FX"
GEARBOX (CHARACTERISTICS)EATNG8
CONVERSION GUIDANCEWITHOUT CONVERSION
DEFINITION TO FOLLOWINITIALE RANGE
ENGINE (TYPE)EP TYPE ENGINE
ROOF (EXT. ASPECT)BODY COLOUR ROOF
Fuel Supply-Engine
FUELUNLEADED PETROL 95 QUALITY A/B/E/E+
EMISSIONS STANDARD (ENGINE)EURO 6.3 ENGINE EMISSION CONTROL
CAPACITY1600 CM3
FUEL TANK INSULATIONWITHOUT FUEL TANK INSULATION
COOLING MOTORRADIATOR EP28 28DM2 BRAZED ALUMINIUM
CRANKCASE GAS CIRCUIT HEATINGW/O HEATER CASING GAS CIRCUIT
EOBD SELF-DIAGNOSIS SYSTEMWITH "OBD" AUTO-DIAGNOSTICS
DEVICE (ANTIPOLLUTION)WITHOUT ANTI-POLLUTION DEVICE
VEHICLE TECHNICAL DEPOLLUTIONEURO 6.3 VEHICLE TECHNICAL EMISSION CONTROL
FANVARIABLE SPEED FAN 200W AERO DYNAMIC FLAP
INJECTION ASSOCIATED VARIANTMOUNTING BOSCH
DRIVE TRAINPHEV DRIVE TRAIN
TANK FILTERRESERVOIR FILTER INTERIOR
STOP AND STARTWITHOUT STOP AND START
Gearbox Transmission
FINAL DRIVE RATIOFINAL DRIVE RATIO 15 X 58
WHEEL STYLE19-INCH STYLE WHEEL
CLUTCHWITHOUT CLUTCH
RIM/TYRE SIZE19 INCH TYRE FIT
TYRE (SIZE, TYPE)205/55 R19 97V TYRE
DRIVING WHEELS2 DRIVEN WHEELS
WHEELS FITTEDWHEELS FITTED 7 J19 RIM OFFSET 41
WHEEL (TYPE)ALLOY WHEEL ASSEMBLY 1
GEARBOX TYPEGEARBOX TYPE EATN8
Suspension-Steering-Brakes
BRAKING ASSISTANCE IN REVERSE GEARCOLLISION WARNING - RCTA
REAR ANTI-ROLL BARREAR ANTI-ROLL BAR STIFFNESS 25000 NM/RAD REINFORCED
FRONT ANTI-ROLL BARFR ANTI-ROLL BAR STIFFNESS 30000 NM/RAD
BRAKE TYPEVENTILATED FRONT DISCS/REAR DISCS
SUSPENSIONNORMAL SUSPENSION
SUSPENSION (ARCHITECTURE TYPE)METAL SUSPENSION
DYNAMIC STABILITY CONTROL SYSTEMELECTRONIC STABILITY PROGRAM
STEERING (OPERATION)HIGH POWER DOUBLE PINION ELECTRIC POWER STEERING
PEDAL BRACKET (TYPE)PEDAL ALUMINIUM
Body Fittings
TOWBARWITHOUT TOWBAR
SIDE MOULDINGS (DIMENSION)WIDE SIDE PROTECTORS + SIDE SILL
WHEEL EMBELLISHER (STYLE)BLACK CENTRE CAPS+BLACK BOLTS DESIGN
ADDITIONAL SHIELD (UNDER ENGINE)W/O ENGINE UNDERSHELDING
EXT. REARVIEW MIRROR COMP. FUNCTIONDRIVER ELEC FOLDING+PASSENGER+DIODE+REVERSE +MEMORY
EXHAUST TAILPIPE TRIMCHROME EXHAUST OUTLET TRIM
ENGINE BAY SOUNDPROOFINGBULKHEAD SOUNDPROOFING +RH+ISOVAC+WHEEL ARCH
WINDSCREEN GLASS (TYPE)STANDARD WINDSCREEN GLASS
WINDSCREEN WIPERFRONT WIPER BLADE WITH RAIN SENSOR
ROOF GLASSWITHOUT ROOF WINDOW
BUMPERCHROME + BODY COLOUR FRONT/REAR BUMPER
LUGGAGE RACKWITHOUT ROOF BARS
FRONT FOGLAMPLED FOG LAMPS + CORNERING LAMP
PANORAMIC VISUAL AIDDIGITAL PANORAMIC VISUAL ASSISTANCE
SPARE WHEELWITHOUT SPARE WHEEL
SUN ROOFWITHOUT SUN ROOF
GLASS (APPEARANCE)TINTED + DARK-TINTED RR WINDOW GLASS
HANDS FREE ACCESS AND STARTINGFRONT ACCESS+BOOT+CONTACTLESS STARTING
Interior Fittings
ANTI-THEFT ALARMVOLUME + PERIMETER + LIFT
FRONT HEAD RESTRAINT4-WAY ADJUSTABLE FRONT HEAD RESTRAINT
REAR SEATMONOCHROME REAR SEAT FX+FOLDING 40/20/40 SEAT BACK
BLIND SPOT DETECTIONBLIND SPOT MONITORING + LANE CHANGE ASSIST
REAR SEAT ARMRESTWITH REAR SEAT ARMREST
INTERIOR ALARM3-SENSOR INTERIOR ALARM
RADIO TELEPHONE2 SMARTPHONES
LUGGAGE COVERSCREEN
REAR SEATBELT3 REEL 3 PT REAR SAFE BELT + UNBUKLED WARNING
FRONT SEATBELTREEL+FASTENING ALARM+CONSTANT PASSENGER/ACTIVE DRIVER FORCE LIMITER
CLIMATE (AMBIENT TEMP)HOT OR WIDER TEMPERATE COUNTRY
AIR CONDITIONINGWITH HEATER MATRIX+ADDITIONAL OUTLET
CHILD LOCKELECTRIC REAR CHILD LOCK
SPEED GRADUATIONSSPEED GRADUATION IN MPH
GRAB HANDLESFRONT + REAR + RETRACTABLE HANDLES
CONSOLELONG CONSOLE + REAR AIR DUCT
DRIVING POSITIONRIGHT HAND DRIVE
MIRROR LINKWITH MIRROR LINK
LOAD SPACE LIGHTINGLED GLOVE BOX LIGHTING
BOOT AND LOAD SPACE LIGHTINGBOOT + LOADING VOLUME LED AUTO LIGHTING CONTROL
DASHBOARD EQUIPMENTBLACK STRIP+WOOD FILM DECOR
INSTRUMENT PANEL (CHARACTERISTICS)INSTRUMENT PANEL BLACK BACKGROUND WITH MATRIX
LOUDSPEAKERMOUNTING 2 FRONT LOUDSPEAKERS + 2 FRONT TWEETERS
ADDITIONAL BLOWERWITHOUT ADDITIONAL PULSE
POLLEN FILTERWITH+ACTIVATED CHARCOAL+FINE PARTICLE FILTER+GAS
LANE KEEPING MANAGEMENT ASSISTANCETRAJECTORY CONTROL ASSISTANCE/LANE POSITIONING ASSIST (LPA) LANE CENTRING
FRONT PASSENGER SEAT HEIGHT CONTROLFR PASSENGER SEAT HEIGHT ADJUSTER ELECTRIC HEIGHT ADJUSTMENT
DRIVER SEAT CONTROLDRIVER’S SEAT WITH MEMORY CONTROL+CUSHION FRONT ADJUSTMENT
FRONT PASSENGER SEAT CONTROLELECTRIC FRONT PASSENGER SEAT CONTROL
DRIVER SEAT ADJUSTMENTDRIVER’S SEAT TILT BACK ELECTROPN LUMBAR SUPPORT
FRONT PASSENGER SEAT ADJUSTMENTPASSENGER ELECTROPNEUMATIC LUMBAR ADJUSTMENT
STOWAGE BINSTORAGE BOX WITHOUT COOLING
SATELLITE NAVIGATION SYSTEMCONNECTABLE NAVIGATION SYSTEM
HEADLAMP BULBSECO LED
TRAFFIC INFORMATION READERLKA STRUCTURAL EDGE
DISPLAY12-INCH COLOUR HD TOUCHSCREEN DISPLAY
COURTESY MIRRORDRIVER+PASSENGER CONCEALABLE MIRROR WITH LED LIGHTING
FOOTRESTWITHOUT FOOTREST
CUSHION PADDINGPADDING WITH PASSENGER DETECTION PAD
FITTING REAR HEAD RESTRAINTMOUNT 3 REAR HEAD-REST
HEATING ELEMENTDRIVER + R1 PASSENGER HEATED SEAT
FRONT LATERAL AIRBAGFR CHEST/PELVIS SIDE AIRBAG+INT+FR/RR CURTAIN
FOOTWELL LIGHTINGFOOTWELL LIGHTING WITH LED
AIRBAG DEACTIVATIONMANUAL AIRBAG DEACTIVATION
HEADLAMP HEIGHT ADJUSTERREMOTE MANUAL HEADLAMP ADJUSTMENT
WIFIWITHOUT WIFI
STORAGE (DRIVING POSITION)STORAGE COMPARTMENT BRAKED OPENING
RADIO RECEIVERANALOGUE + DAB RADIO RECEIVER
REFRIGERATIONAUTOMATIC AIR CONDITIONING
CRUISE CONTROLACC3 DECEL0 + ACCEL0
DRIVER’S SEAT HEIGHT CONTROLELECTRIC CONTRL DRIVERS HEIGHT ADJ
INTERIOR REAR VIEW MIRRORFRAMELESS INTERIOR ELECTROCHROMATIC MIRROR
AIR CON./TEMPERATURE REGULATIONAUTOMATIC AIR CONDITIONNED BI-ZONE
STORAGE (OTHERS)PLAIN STORAGE POCKET
LOAD SPACE STORAGEBOOT LATERAL STRAP + NET
REAR SEAT PADDINGWITHOUT RR PASSENGER DETECTION
TUNER RADIODUAL RADIO TUNER
OBSTACLE DETECTION SYSTEMFRONT/REAR RADAR OBSTACLE DETECTOR + TRAJECTORY
FLOOR MATFR + RR MATS
RADIO FREQUENCYRADIO FREQUENCY AMT6_FMT4-50-DIAFTAPSTMC_DABT1
LOCKING CONTROLCENTRAL DEADLOCKING + AUTOMATIC LOCKING
STEERING WHEELFULL FLOWER LEATHER ST WHEEL
SEATING ASSOCIATED VARIANTLOWER SEAT ASSOCIATED VARIANT
DRIVER’S KNEE AIRBAGWITHOUT DRIVER’S KNEE AIRBAG
AUDIO PACK AUXILIARY SOCKETAUXILIARY SOCKET AUDIO PACK 2 USB TYPE C
TELEMATIC UNITINDEPENDENT TELEMATIC UNIT
Electrical
ALTERNATORISTT60
BATTERYL3 760 70AH EFBC 760 BATTERY BECOMES EFBC
STARTER MOTORWITHOUT STARTER MOTOR
CEN. LOCKING REM CONTROL FREQUENCYLOCKING REMOTE CONTROL FREQUENCY 433.92 MHZ HETERODYNE
ELECTRICAL EQUIPMENT (SUPPLY)LEOCH BATTERY
BATTERY CHARGERSINGLE-PHASE 7 KW ON-BOARD CHARGER
MULTIPLEXINGNEA R1
ELECTRIC VEHICLE CHARGING PLUGWITHOUT VEHICLE LOAD RECOGNITION
BATTERY CHARGE MEASUREMENTWITH BATTERY CHARGE MEASUREMENT
LIGHTING OF LAMPSAUTOMATIC SWITCHING ON OF THE LIGHTS+AUTOMATIC SWITCHING
Component Manufacturers
Miscellaneous
SPECIAL SPECIFICATIONSTANDARD
MODIF. DURING MODEL YEARWITHOUT MINOR MODIFICATIONS
CONDENSER (SPECIFICATIONS)CONDENSER 23,5DM2 THICKNESS 16
ATMOSPHERIC CONDITIONSNORMAL ATMOSPHERE
VIN PLATEEUROPEAN UNION CONSTRUCTOR’S PLATE + NRE
AIR CONDITIONING PIPESSTANDARD AIR CONDITIONING PIPES
RADIO HEADPHONE SOCKETDOUBLE ACCESSORY SOCKET
TRAFFIC SIDEDRIVING ON THE LEFT-HAND SIDE
SIDE IMPACTSUPPER REINFORCED SIDE IMPACT PROTECTORS
REFRIGERANTAIRCON FLUID 1234 YF
EMERGENCY EQUIPMENTPUNCTURE REPAIR KIT
SURFACE CONDITIONSGOOD TERRAIN
danlat1415
x 24
Unread post by danlat1415 »
Please could you confirm the part number for front drop link for VIN - VF7**************[VIN obfuscated, can be read by forum staff]
x 6950
(2) Anti Roll Bar Rod (Drop Link):
OEM Original, parts 9844264780 & 9817224280 (Nut) , £45.96, & £2.14
Cheaper PSA Part: 1679755380, £20.72
x 2367
x 6950
Only just picked this up via the parts thread Matt (always best to request parts there so they're not missed anywhere else).
As for CD, took me a while as there is no CD specified in parts for your vehicle, however I can confirm the Fascia part is correct and also the harness will be needed: So yes you need a specific harness to connect this to the main unit and of course it will need telecoding in the BSI. They deemed these not necessary, with Audio Streaming via Bluetooth and the ability to play media via USB. Please also note that connecting a CD will not allow copying of media to the internal 'Jukebox' storage according to info I have.
CD Harness for SMEG units, part: 6571QY, £78.13
The CD is not coming up against your vehicle, and the only one I can see that is compatible with the electronic architecture and build date is part: 1629118180, £328.02
Wheel Arch
(11) Right Wheel Housing Mudguard, part: 9819974080, £128.51
Micko
Unread post by Micko »
Can i get the number for the bolt thats holds the joint/yoke that connect the steering colum with the steering rack.
x 2367
GiveMeABreak wrote: 05 Feb 2025, 10:21 Only just picked this up via the parts thread Matt (always best to request parts there so they're not missed anywhere else).
Sorry Marc, it is on the parts thread, just a bit further up (a few other queries came in directly after mine which have been answered, hence my cheeky post as I reckoned I'd got lost in the noise somewhat :) )
Thanks for the comprehensive answers. Bit confused the fascia is correct (which is the one with a CD shaped hole in it!) but no CD drive coming up, very strange!
Not sure I've got the internal jukebox, or else I'm feeling daft not noticing it if so!? :-D will check when back at the car again this evening.
Will get digging for lead and drive.
Wheel arch liner image is spot on - number 18 is the grille I tried to describe. Current liner has a removal panel in same spot, but it's solid!
As said intercooler is ahead of it so a route for airflow seems eminently sensible. More digging for me!
Thanks again
GORAX
x 14
Unread post by GORAX »
Hi everybody,
I need part number for gearbox oil seal and drain cap seal.
GOOGLE TRANSLATE
