Citroen dispatch control arm bolt
bitsas004
Unread post by bitsas004 »
Does anyone know the part number for this particular bolt (7) in yellow) mine got bad thread and i looked everywhere but was unable to find a new one
bitsas004
Re: Citroen dispatch control arm bolt
anyone ?
Steve Walsh
x 518
Unread post by Steve Walsh »
I think the number you need is 352278, Fitted a couple a few weeks ago and I got the number from the empty bag that was still in my workshop. Sure thats what it is but worth a check with your supplier
bitsas004
its definitely not that because this bolt has a double washer and is actually pretty short
Steve Walsh
x 518
If you go to your dealer with that picture and your vin number he will be able to order one for you
x 1496
We can help if you need an original genuine part number, part diagram or vehicle factory build sheet and can't already find the info you need on the Forum. For this service, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future part number requests for up to 3 years *, so excellent value.
We do NOT provide Technical Documentation or Wiring Diagrams as part of this Service! We may only help with these if Staff already have them.
* Please note that the FCF can only provide this service to donating members for as long as the Stellantis Group provide access to us.
If interested, links are below, then provide your vehicle's VIN in full, which will be masked automatically when you submit your post.
A response to your question by a Forum Admin requiring parts or specific vehicle information requires you
to have made a current contribution
(Min. £10 / €11.48 or equivalent) to the Forum.
To Upgrade Your Membership & Donate Click Here
For Further Information About Vehicle Parts and VIN Numbers Click Here
bitsas004
Didnt realise my membership has ran out, just donated again
x 1496
Possibly 352278 - £7.21 from the dealer. Post the VIN and we can confirm.
bitsas004
vin is: VF7**************[VIN obfuscated, can be read by forum staff]
x 1496
352278 is correct.
bitsas004
I am so sorry the bolt i was looking for is nr14 in the picture, its relatively short bolt with 2 washers, again sorry for pointing out the wrong one in the first place
moizeau
x 423
Unread post by moizeau »
Not long ago had to change my wishbone and had the same issue with the same bolt. I cleaned the thread if the bolt. There were shards of ally in it where, I'm guessing, it had been rattle gunned it previously. Also you'll need to run a tap into the thread on the wishbone. Can't remember the size but it isn't a standard thread, it's finer.
Pete
bitsas004
moizeau wrote: 28 Feb 2025, 08:17 Not long ago had to change my wishbone and had the same issue with the same bolt. I cleaned the thread if the bolt. There were shards of ally in it where, I'm guessing, it had been rattle gunned it previously. Also you'll need to run a tap into the thread on the wishbone. Can't remember the size but it isn't a standard thread, it's finer.
Yes mate its fine thread and mine is completely messed up dont want to put it in new control arm, its a very tight hole around the bolt it can get damaged even by rubbing on the sub frame as it goes out, anyway blody hard to find new one, only FAG brand sell control arms with new bolt set, but not going to buy it just for the bolt obviously
x 1496
Part no for bolt 14 is 352252 = £4.58
Says M12 x 1.25 thread x 30.5mm with captive washer. I imagine it is 8.8 spec at least - might be difficult to track down something so short elsewhere other than the dealer.
bitsas004
Thank you just found one on ebay finaly
