need a rplacment engine BHZ
phil227
Unread post by phil227 »
Hello we are after a replacement used engine for our Peugeot partner engine code BHZ is it possible to use ( other same type engine with similar codes )
There looks to be a difference as ours has add blue , but what difference does that make in compatibility ? Thanks Phil (North Wales)
x 6958
Re: need a rplacment engine BHZ
Hi Phil, I'll need the VIN and then I can provide you with the correct official part number for the engine.
phil227
Ok thanks its VF3**************[VIN obfuscated, can be read by forum staff]
x 6958
Phil - your missing one. Should be 17 long not 16. Check the last 8
Oldpug
x 93
Unread post by Oldpug »
Contact Dean Hunter www.peugeotparts.co.uk he may have one.
phil227
ok its VF3**************[VIN obfuscated, can be read by forum staff] SORRY
x 6958
Ok, that's the one...
Ok, so be aware your vehicle could be fitted with 2 variants, both with the same marking, one fitted with the oil pump without control solenoid valve and the other with the oil control pump fitted with the solenoid valve. I can't help you with this part as even official parts says either one.
(1) New OEM Engine Marking BH01 without control solenoid, part: 1612521380, £10,264.70
Standard Exchange Engine Marking BH01 without control solenoid valve, part: 1612521480, £5,507.90
New OEM Engine Marking BH01 with control solenoid valve, part: 1614411580, £9,655.57
Standard Exchange Engine Marking BH01 with control solenoid valve, part: 1614411680, £5,657.93
phil227
Thanks for your help .
