Missing fuse module nut, what size is it?
rocco
- x 3
Re: Missing fuse module nut, what size is it?
Just a little update. I connected a jumper cable to the negative battery terminal last night and to the car body but it made no difference. I also tried connecting it to the bolt of the engine mount - nothing.
I still get that click and it's coming from the area of the starter motor, my neighbour confirmed that for me. I don't have space to jump start the car but I will try it and maybe it'll jolt the starter enough to revive it.
I also removed the battery tray, just to have a peek under it. The earth strap to the gearbox isn't exactly easy to reach but it is at least secured so I believe it's hammer time. After watching the Laurel and Hardy video, a few smacks and it might start working again - I hope.
Steve Walsh
- x 515
Very careful if you hit the starter with a hammer. there are magnets inside and easily broken...
Steve Walsh
- x 515
I would still try a 12v to small terminal on starter, If it turns over it works and your problem is elswhere
rocco
- x 3
Ah yes, you're right. I'll try that first if I can, but I'm not convinced that I'll reach/see the terminal from underneath. Thank you.Steve Walsh wrote: 30 Jan 2025, 07:26 I would still try a 12v to small terminal on starter, If it turns over it works and your problem is elswhere
Steve Walsh
- x 515
A long piece of wire clipped onto positive terminal, connected to a long screwdriver or similar and touch on small starter terminal from underneath.
rocco
- x 3
Hi Steve. By "small terminal" on the starter do you mean this one that the red arrow points to?Steve Walsh wrote: 30 Jan 2025, 07:26 I would still try a 12v to small terminal on starter, If it turns over it works and your problem is elswhere
Steve Walsh
- x 515
That's the one, that energises the solenoid / starter. The one with blue on becomes live when the small one receives 12v. the one on the right is 12v from battery
rocco
- x 3
Finally I've had time to get under the C4 today and given the SM a gentle tap of encouragement with the hammer. No change.
Now I'm going to put 12V directly to it but it isn't exactly easy to access and I don't think I'll get the jump leads to fit. How easy is it to remove? It seems like there are only two bolts so if I can access them by feel, it might be easier to remove it to test?
Steve Walsh
- x 515
Doesnt need to be jump leads the size of car starting leads, onto the small terminal it can be a length of wire like house wiring size or similar, I just have a set of them with tiny crocodile clips for testing various things
rocco
- x 3
I appreciate your support Steve, I now just want to be absolutely sure I get the right post becasue the image I shared above doesn't look like the same starter motor as I have.
I think it's the one with a yellow box around it, am I right? I've taken the photo from underneath in case it's not clear.
Steve Walsh
- x 515
It is the smaller one, It is a 5mm thread with a nut/spanner size 8mm
The large top one is battery power / heavy duty. The lower large one is from solenoid into starter. You need a 12v feed into the small one, if the starter turns the engine that starter is OK.
rocco
- x 3
P**s! I just tried it using the exposed terminal/post and got nothing - and now I know why.
In this photo I can see that it appears to have the main cable connected to that post, so tomorrow I'll try it in the proper place (yellow box).
I do hate being thick.
Steve Walsh
- x 515
Use the small one above it
Steve Walsh
- x 515
The small one as in this picturerocco wrote: 30 Jan 2025, 19:36Hi Steve. By "small terminal" on the starter do you mean this one that the red arrow points to?Steve Walsh wrote: 30 Jan 2025, 07:26 I would still try a 12v to small terminal on starter, If it turns over it works and your problem is elswhere
rocco
- x 3
OK, thanks I will try but I don't think I'll get any purchase on it with jump leads. What is the cable that is already connected to it? Where does it lead?
