Peugeot 508 MCP clutch not biting
Skopeu
Hi all, have a 2012 Peugeot 508 that came in with fault code p1755 clutch jammed, diagnosed as the release bearing leaking. Replaced it with a 3 piece LUK kit (flywheel seems perfect) and went about the programming process using diagbox and kept cancelling at the clutch biting point stage. Checked live data and clutch travel wasn't changing with the brake pedal pressed so removed the box again and changed the position sensor on the bearing which has made no difference. Checked the wiring harness from the bearing to the MCP control unit and all showing good so replaced the MCP unit on the side of the gearbox and now only coming up with faults for clutch programming and gearbox programming incomplete (can't remember the fault codes). Has anyone else come across this or know of any solution that may help
- x 6946
Re: Peugeot 508 MCP clutch not biting
Sitting Comfortably?
(*) According to equipment and engine.
| Fault Code: | P1755 |
| Description of Fault: |
| Conditions for Fault to clear: |
| Downgrade Modes whilst Fault is active: |
| Symptoms: |
| Suspect Areas: |
- x 1496
Have you done the bleeding / pressurising / programming procedures? Are you using an external power supply when doing this? Was the clutch the proper one for the EGS box - it is not the same as the manual one apparently.
Skopeu
Yes sensor clicked into place perfectly and bolted 100%
Yes doing all the pressurizing/bleeding procedures ok but won't do the programming of the clutch. Using a GYS battery support unit and definitely the right clutch kit, checked the LUK number against the servicebox part numbers
