Steering rack ecu, from old to new
Micko
Unread post by Micko »
Hallo. Maybe i have to change my steering rack on my 2.0 hdi 2016. When i search the OE number on the rack i can se that almost every rack fits the car. So i guess the specific oe number is ment for the steering racks ecu. Is it possible to switch the ecu from my original one to the new one that i buy.
x 6948
Re: Steering rack ecu, from old to new
Hi
Unfortunately no. These are NOT the same racks for this model. They vary with different part numbers from vehicle engine to engine and also model (Family Saloon / Estate Leisure), as well as specific options fitted to the vehicle and subframe type. These changed throughout the build date with some being low power and others high power units, so you will need the exact type for your vehicle and with the correctly configured ECU relevant to the vehicle's systems and options.
Micko
this is from autodoc. they say that all these different numbers will match.
do you know if the rack has to be codeed after installation
x 6948
Yes, the ECU has to be coded for the exact vehicle - hence why the part numbers are different (as they are supplied by Citroen pre-configured for the correct settings on a per engine, per vehicle basis). So the Autodoc references are meaningless in this regard.... it's like saying 'I have a 'Ford', which rack do I need?' They may list part numbers that were fitted to a particular model, but they can all still be different based on options, equipment body style and engine variant.
Micko
Okay. Just found a rack with the same number. All new on eBay in Germany.
Micko
Just ordered the new rack with the same number. Will i have to code/program it after installation.
x 6948
Great.
x 1476
Unread post by xantia_v6 »
Parts like that can come pre-coded or not... If it is pre-coded, then there is nothing to do, if not then it will need programming parameters to match your model of car.
Micko
Micko
Just found out that its probably the bolt that holds the the steering joint to the steering rack. Its a bit worn. Just tighten it really hard and the steering wobling and knocking while driving is gone. Stil as a knocking sound when turning the wheel when its off. Så might have to get a new bolt. Anyone know if its possible to get at bolt as a spare part
