sar77
x 4
Unread post by sar77 »
GiveMeABreak wrote: 15 Jan 2025, 10:11 @Sar77: Here you are - note items marked 'NFP' are no longer available from Citroen.
click Image to Zoom
Thanks Marc,
Am I understanding correctly? Of all these (pre-equipment) parts, only position 70 was installed in the factory in 2014?
Sarunas
Together we can do more
Micko
Unread post by Micko »
Kan i please get the number for inner tie rods
x 6963
sar77 wrote: 15 Jan 2025, 20:33
Thanks Marc,
No, everything would’ve been fitted as shown if your vehicle was supplied with additional heating at the time. It just means that for replacement parts these will be ordered directly from Webasto by the dealers where shown at a in the Notes.
Micko
x 1457
Micko wrote: 19 Jan 2025, 11:43 Kan i please get the number for inner tie rods
1610817680 - not handed, £ 68.45 each Cheaper parts for older cars 1682730480 @ £24.55 each
Micko
stickery74
Unread post by stickery74 »
Hi Marc, Could I get part numbers for a MAF meter/sensor and a Crankshaft Position sensor please.
VIN is VF7**************[VIN obfuscated, can be read by forum staff].
TIA, Rob
oli3442
x 4
Unread post by oli3442 »
Hi, please could I have the part number for the brake vacuum pressure sensor if possible.
I have a P0555-12 code 'Braking circuit vacuum sensor short circuit to positive' and good voltage at the connector so was going to try changing this.
Micko
Can i get the number for the steering rack.
Vin number is
WillyR
(Donor 2026)
x 6
Grand Picasso II (B78) Driver Door Mirror (RHS UK) - Part number Please
Unread post by WillyR »
Good afternoon everyone,
I hope I have made this request in the right place.... The Motor mechanism on my driver door mirror has stopped working - everything else still works OK. I suffered a cable break last year in this mirror, which I fixed, noticing the the loom down into the door was far too tight, so I managed to free it up quite a bit, but the mirror is determined to punish me for something. I have investigated many pre-owned mirrors but the advertisers all skip out several of the functions, and I am loath to have to swap bits around too much.
Please can you give me the PSA part number (2015 model 2.0 ehDi 150bhp EAT6 Exclusive) - VIN VF7**************[VIN obfuscated, can be read by forum staff]
Sincere apologies if I have posted this request in the wrong place.
WillyR
2015 (Jul) C4 Grand Picasso 2.0 Bluehdi 150 EAT6 Exclusive+ now running on 17" wheels - SO MUCH MORE COMFORTABLE AND SMOOTH THAN 18" - AND better fuel economy :) =D>
Krakatoa
Unread post by Krakatoa »
Good evening, I would like to know if this car has keyless start. Also, what code does the headlight switch control have? Thanks
x 1457
stickery74 wrote: 19 Jan 2025, 18:57 Hi Marc, Could I get part numbers for a MAF meter/sensor and a Crankshaft Position sensor please.
TIA, Rob
MAF - 1920LK £275.76
CPS 1920EH £ 83.48
x 1457
Micko wrote: 20 Jan 2025, 15:44 Can i get the number for the steering rack.
Vin number is
1638434980 - £1791.18 + £300 surcharge for the old unit.
x 1457
Re: Grand Picasso II (B78) Driver Door Mirror (RHS UK) - Part number Please
WillyR wrote: 21 Jan 2025, 13:08 Good afternoon everyone,
WillyR
Yes, right place!
There was a 7 missing from the VIN after the VF - I've corrected it.
RH Mirror - 1610545980 - £909.44
x 1457
Krakatoa wrote: 21 Jan 2025, 13:23 Good evening, I would like to know if this car has keyless start. Also, what code does the headlight switch control have? Thanks
Please note, that since we have to pay for access to the parts database:
A response to your question by a Forum Admin requiring parts or specific vehicle information requires you
to have made a current contribution
(Min. £10 / €11.48 or equivalent) to the Forum.
To Upgrade Your Membership & Donate Click Here
For Further Information About Vehicle Parts and VIN Numbers Click Here
