Dear forum,
i have a toyota proace which is a peugeot traveller transporter with the 2017 116HP 1.6 engine.
I have got a P242F-00 error with the current mileage of 195.000 km, I think the dpf is not that good but could work for some to thousand km more so that I could repair in summer.
I read the ECU errors with the diagbox 9.68, and tried to clear the dpf error by telling the tool that I replaced the pdf, however I failed to do this.
The diagbox didn't accept this and prompted: "Resolve the Problem causing the interruption of the test"
Do you have any idea what do I do wrong? thanks!
P242F fault on Toyota Proace 1.6 116HP
- x 1485
Re: P242F fault on Toyota Proace 1.6 116HP
Says engine running...that will be the fault preventing the update.
6 mbar pressure drop looks good, it should be fine after you have told it it's been replaced.
daba
Hi Richard,
Thanks for feedback
But I am very confidente the Engine was off
so I am wondering if there is another requirement …
Thanks for feedback
Dormouse
- x 696
Your readings show 999 rpm in one page and 767 rpm in another so it looks like you need to go back and redo the procedure.
daba
Hi,
Tried again twice, didn’t work
daba
Hi,
have found this forum sntry https://www.peugeotforums.com/threads/h ... ox.368033/ which exactly descrives the problem i have got, unfortunately it seems not beeing solved :-/
daba
Finally used diagbox 9.150 could clear faults
LedZep
- x 30
I had similar problems with 9.68 version of Diagbox. For example, i couldn't reset the wear counter after ATF oil change of automatic gearbox. Diagbox 9.150 it's much more stable.
