208 1.2 petrol wont rev over idle
moizeau
- x 428
Re: 208 1.2 petrol wont rev over idle
A washed liner would normally cause wear on the rings and a glaze on the liner. If it were mine I'd borrow a valve from another cylinder and have a quick lap to confirm valve seat condition. If good put a new valve in, turn the head upside down and fill the combustion chamber with diesel and leave overnight to check for seepage. If you can get the piston out from underneath to confirm the ring condition all the better. Bet the bit of valve is in the exhaust.
Pete
tmead
- x 11
thanks, it's going to have to wait until after the bank holiday and a few other jobs. I may have a play with lapping in a swapped valve to see if it will clean up. The seat doesn't look bad.
tmead
- x 11
And now i've messed up - dropped a collet on the floor as I was clearing up the stripped parts to make space for another quick job, and I can't find it. That's a real pain. A quick google last night didnt show anything up, although I dont have the OE part number to search in detail.
Valves are surprisingly cheap though, at around a tenner. After a bank holiday break i will have a try at swappgin and lapping a valve and see how it cleans up and seals. Trouble is, I will then need the right number of collets !
tmead
- x 11
If anyone is able to point me to the part number for the collets I'd appreciate it. I can't find that one that I dropped.
- x 6960
Guys - if you are requesting parts, please use the official thread as I may not see your request elsewhere unless I read through every post - and I don't have time for that:
Official Parts Request Thread
(3) Valve Half Cone, part: 9816171280, £3.48
tmead
- x 11
Thanks for the nudge Marc, I'll make sure I use that in future.
tmead
- x 11
I released the next door exhaust valve too, and that was pretty badly pitted, so its not only the one thta burnt that's bad. I gave up on the idea of resurecting the engine and sourced a replacement. Swapping is pretty straightforward, just strip the bumper, rads and font grilles off and the whole powerplant comes out without bother.
Replacment engine in and we're almost good to go - MOT today ! fingers crossed.
I may have a look at the engine ethat came out, just to get it put back together, but I'm relally not sure. The manifolds are quite oily, so i suspect its been burning oil. Its not worth doing the valve stem seals without proibably replacing all the exhaust valves. Im not sure I can summon the energy for this project, even though the engine ready to run should sell for around the 500 quid mark by the look of ebay. I have other things to do !
If anyone wants a project puretech 1.2 engine, let me know !
Netwerkers
- New User
Hello tmead.
I know this post is almost a year old now. But i think I might have the exact same problem, or at least your symptoms are exactly the same...
My Citroen C1 with the 1,2 VTi PureTech starts and idles rough (sounds like its only igniting two cylinders) no throttle response at all, engine light on, can not contact the ECU (or yes if I chose an older model, but seems a bit odd) but all the other modules works fine.
It reports error on injector 3 and throttlepedal open to poistive...
I tried ignition changing ignition coils and moving the sparkplugs around to no luck at all. Then I tried to disconnect throttle pedal and throttle body, stil no difference
Then I found you amazing post, thank you so much for making a detailed follow up!
I have just one question, how did it end? Did everything come back to life after engine replacement? No more dead throttle and fan turning on after?
Hope you see this
Hope you see this
tmead
- x 11
Sorry, missed this one !
Basic compression check gives a clear indication of valve failure.
Replacement engine is fine, although just had a dead coilpack. It burns some oil but that is normal for these I think. May get valve stem seals in a year or so if my son still has it !
I've popped two valves into the original engine and it's back together. Not sure if I should keep it as a spare or flog it ! Space is a premium, so I'm leaning towards selling.
BarryP207
- x 6
Hi, I have been reading your post with a lot of interest thanks?
I have a 2008 and like you I think it's easier to swap the engine? Is there a guide or can you give me some pointers? If I get the exact same type of engine, EB2FA HMR, will the ECU get upset? If I swap everything over from my engine will it flag faults or not start? I have been quoted £2.5>£3k to have my engine reconditioned? So, I will try and find a low mileage one? Oh, I have diagbox? Do I need to back the ECU or something??
Thanks in advance guys!
Baz.
Baz.
tmead
- x 11
Engine swap was no big deal really. You'll need to drop the gbox oil, pull the driveshafts, disconnect electrics at the fusebox, disconnect and remove exhaust, disconnect fuel pipes, pull the headlights, bumper rad and crash bar and fold the aircon condenser aside if there's still gas in.
The engine and box come out through the front pretty easily.
I don't think you'll need to do anything with the ecu about injector mapping etc on the petrol ecu. I didn't. That's a diesel thing.
I wouldn't fret about recon. There's enough engines around to pick from.
Cambelt is easy while the engine is out.
