Hi All Happy New Year!
I had commandeered a previous thread but still
Need advice for replacement method for these please.
I am collecting today. Ordered a pair so I can swap both.
Faulty NSR axle bump stop (rubber missing)
Good OSR axle bump stop
Replacement pair
Thanks in advance
3008 MKII Rear Axle Buffer replacement
Jonsredpug
- x 1486
Re: 3008 MKII Rear Axle Buffer replacement
They appear to just have a plastic barb on the bottom. I doubt you can access the back to release the tabs so just lever them out and break the clips, then push the new ones in.
Jonsredpug
Thanks Richard
That’s what I was thinking, and you’re right there is no lower access, so it must be a destructive removal. Was concerned the barb clips might hinder reinsertion if they stick in the hole.
Cant seem to find anyone who’s done these myself. Would rather avoid the garage fees for a trivial part.
Jonsredpug
I’m going to try to insert a flathead flush to the base and wiggle see if I can squeeze the tabs in a bit first just in case.
Jonsredpug
Update for anyone else in similar situation. Weather too cold, driveway not flat enough I gave up 30min into my efforts, and went to the garage.
€40 to swap out. One note, I bought these as they were the only new ones I could find but they have a slightly different OEM code- the correct part (after removal of the old) was 9818969480. Although apparently identical the clips didn’t grab at the rear of the union and we bonded it to the arm instead. Serves me right buying from China but was 1/4 the price for a new pair than a used single.
