Eolys?
- x 6957
Re: Eolys?
Great, no worries.
Martin3008
Re: Eolys?
Hi Team,
Would it be possible to let me know what additive is needed for my car ?
The car is exactly 100k miles.
My mechanic topped the tank for the first time with a white bottle saying "POWERFLEX" on it and i hope it can be mixed with the original additive.
After around 7 months and around 5k miles the counter was reset that was filled up. Is that a problem ?
Thanks in advanced
Thanks in advanced
- x 6957
Re: Eolys?
You have a reservoir (so not a pouch based system) and require Powerflex Additive.
The counter should be reset when the additive reservoir is topped up, but won't do any harm if this was a little later.
Martin3008
Re: Eolys?
Thank you Marc for your reply. I feel much better and glad that my DPF is maintained properly.GiveMeABreak wrote: 14 Dec 2024, 20:21 You have a reservoir (so not a pouch based system) and require Powerflex Additive.
Happy holidays and thank you again for helping out.
timf33
Re: Eolys?
Good morning, I need to fill Eolys tank.
Vin VF7**************[VIN obfuscated, can be read by forum staff] 2012 C4 Picasso
I have located what I think is the tank on the O/S in front of rear wheel.
I assume where I fill is on the top, however I can't see the connector colour.
Please could you confirm type of fluid required and if I'm correct in thinking its a tank, not pouch.
TIA Tim
TIA Tim
- x 6957
Re: Eolys?
You can't just fill it up - it needs resetting with the diagnostic tool.
You require Powerflex additive and yes it is a reservoir system not a pouch. It is filled by gravity, so needs a filling kit and a professional level diagnostic tool to reset the additive counter or the engine ECU will not know you hahve topped the fluid up (it is not physically measured).
timf33
Re: Eolys?
Thanks for that Marc, much appreciated.
Sorry, forgot to say I was aware of the resetting required and have access to a diagnostic tool for doing this on my original post.
Any recommendations where to get refill kit from online?
TIA Tim
TIA Tim
- x 6957
Re: Eolys?
No worries, there are plenty of sellers, even Amazon sell it now:
https://www.amazon.co.uk/DPF-Additive-P ... 4d21&psc=1
Just make sure you put in at least 1 litre when refilling.
Best
Best
Igor01
Re: Eolys?
Peugeot 508 sw hdi 2011
- x 1347
Re: Eolys?
Please write all messages in English - use a web translator if necessary.[translation]
Good evening, I got a message about low level of particle filter fluid. What type do I need? Thank you in advance for the answer!
Igor01
Re: Eolys?
Good afternoon! A message appears indicating that the fluid level in the particulate filter is low. What type do I need? Thanks in advance for your answer!
Igor01
Re: Eolys?
Good morning! A message appears indicating that the fluid level in the particulate filter is low. What type do I need? Thanks in advance for your answer!
- x 6957
Re: Eolys?
For your 508 (W2) of this build year you need Eolys EXTEND (Black) fluid - NOT Powerflex.
wurlycorner
- x 272
Re: Eolys?
Hi all
I haven't posted on here is absolutely ages - life getting in the way etc. I still have all my previous Citroen's and will get round to updating some of my previous threads at some point. Reason for this post is on Christmas Day I made a rash purchase... An X7 with an eolys fault (P1442 - o/c, intermittent) and I collected it yesterday. nb: I can't even blame alcohol for the rash purchase because I didn't drink a drop on xmas day!
VIN is: VF7**************[VIN obfuscated, can be read by forum staff]
Please could you check and confirm:
The correct additive fluid for this car;
The wiring diagram for the tank pump (so I can check and confirm if it's pump/wiring that's at fault etc.);
The part number for the replacement tank (complete).
Thank you
Thank you
Iain
CX DTR T2 Safari (silver)
Iain
- x 6957
Re: Eolys?
Hi Iain.
For the C5 X7, it needs a specific Eolys fluid, which is Eolys EXTEND (Black).
(9) PEF Additive Tank, part: 1500NK, £475.73
As for the fault Code:
So there is the possibility of the engine fusebox to consider here.
Diagram for Particle Filter:
With the exception of the wiring codes, most of the component codes are indexed here:
PSA Electrical Diagrams - Wiring & Symbols Codes Index
| Fault Code: | P1442 |
| Description of Fault: |
| Conditions for Fault to clear: |
| Downgrade Modes whilst Fault is active: |
| Symptoms: |
| Suspect Areas: |
