Declutching Control Pipe
macplaxton
Unread post by macplaxton »
GiveMeABreak wrote: 21 Dec 2024, 10:31
Huskyxantia wrote: 21 Dec 2024, 10:21 Brake Clutch Slave Master Cylinder Pipe Connector Clip Seal
Ok so that helps.
No is the answer, these look to be the connections on the declutching control pipes and are part of the complete pipe assembly:
(13) Declutching Control Pipe, part: 2056T0, £47.90
(14) Declutching Control Pipe, part: 9678377780, £37.84
Hi, Haven't been in for years, please do excuse me for butting in. I was just browsing this thread and have an answer.
The top-hat seal on the left of the picture (was it pinched from a Fiesta thread on Reddit? :lol: ) is used not only on Stellantis group cars, but also Fords and VAG.
AFAIK, the rubber seals part number 2156.15
a.k.a. Ford (i.e. Mk6 transit master) 1430502
If you need the plastic piece on the right, I think you might as well buy a quantity from China on eBay / AliExpress / Amazon because cheaper. UK stock is quicker/costlier - either way they can be obtained on their own.
Hope this helps.
x 6947
Re: Declutching Control Pipe
I've moved your post into a separate topic as that thread is for official parts requests and responses only. :wink:
Nothing to do with Reddit - those are official parts diagrams. :)
macplaxton
No problem. Hopefully useful to someone.
The Reddit comment was referring to original photo supplied by the OP as the Google Image search pinged back a match with a one year old Reddit thread post about a Fiesta clutch of an identical hand and oil spots on it.
I understand the rest of the post was slightly OT, but it did include the official Citroen part number 215615 which could be obtained from the dealer.
There are one or two parts on Servicebox that at first glance appear to only be part of another whole assembly, but are actually available individually from the dealer. Off hand I can't give an example, but if it comes back me, I'll start a new thread. It's usually small bits like this that show on one page/vehicle, but not another's.
Huskyxantia
x 927
Unread post by Huskyxantia »
Think I've got a couple of these end pieces , I'm going to check what's on mine and replace if need be. I'd say if they spilt then over a few miles of working the clutch then air would get in the eventually knacker the master cylinder. Well done macplaxton, some times other insights can shed light on the same matter but from a different angle.
:-D
Huskyxantia
x 927
https://www.ebay.co.uk/itm/387612481319 ... media=COPY
Just purchased these . Link & price correct 29.12.2024.
:-D
x 8151
That looks to be a bit of a bargain Husky, let's hope it helps resolve your issue at last!! :-D
Huskyxantia
x 927
These photos show the off centered hole mentioned a bit back on this thread , shown with & without an attachment, if this is meant to be then OK, but if it isn't it could be a problem. Surely fluid needs to travel a straight passage ? Just a theory. Look for yourself & see what i mean.
:-D
Huskyxantia
x 927
:-D
Huskyxantia
x 927
Above , are they needed ? Look more like a left hand drive car then right hand , are they just more to add to the confusion?
:-D
Huskyxantia
x 927
The rubber pieces were to keep dirt out of the part while in store or transit
:-D
