Once you get everything running OK Alam, I would be very tempted to enable the AM reception to see how good (bad?) it is.
If you do this please let us know.
Peugeot 3008 Hybrid RT6 not booting.
OnlinePaul-R
- x 1939
Re: Peugeot 3008 Hybrid RT6 not booting.
AlamSAsif
I will try it tomorrow and post the result.
AlamSAsif
Everything works ok thanks to all of you. The only think with didn't work is the status of hybrid (car is running on engine or battery) on the display.
I only change the RT6 unit on my car and the settings for the Hybrid info should be in this unit settings. The BSI settings are remain the original one. If possible can you please explain what the following settings do? If I change them, is it make my RT6 stop working. I just want to test these settings.
Telematic/Other Functions:
* Display of audio information on the instrument panel an on the head up display.
* Display of Status log
* Trip computer function
* Suspension IHM
* Display of vehicle warning messages
* Separate Control Keypad
Telematic/Customer Options
* Multifunction Screen
* Multiplexed Control Panel
* Speed Regulation
* Suspension IHM
* Speed Regulation
AlamSAsif
Hi Paul. I enable AM reception settings. Didn't do any diffence in radio reception. Didn't drive the car for long, just drive it for couple of miles.
OnlinePaul-R
- x 1939
So, even though you enabled it AM reception wasn't then offered as an option? Maybe there's a secondary (or even tertiary!) tick box somewhere. I wonder if the AM is now enabled but the aerial set-up doesn't support it?
AlamSAsif
Hi.
Manage to sort out the Hybrid pages using mirascript. Everything thing is working as it should be.
Thank you everyone for all your help.
Regards
Shah
Regards
Shah
inzuno
Hi,
I have the same issue on my Peugeot 508 RXH
After SD replacement I lost my Hybrid pages.
How did you manage to get them back with mirascript?
Could you share your config file? (to extract your config you can use mirascript USB file copy here: https://www.forum-peugeot.com/Forum/att ... zip.15688/ )
Thanks in advance!
Thanks in advance!
OnlinePaul-R
- x 1939
It could be some time before you get a reply. AlamSAsif hasn't been back since June.
inzuno
Thank you for the info, may I try to PM him?
OnlinePaul-R
- x 1939
Well, you could certainly try. No guarantee that he has email notifications switched on though!
aronbv
- x 4
Hello guys,AlamSAsif wrote: 25 Apr 2020, 16:04 Hi.
Regards
Shah
can anybody help with this info?
TIA
