Martin3008
Unread post by Martin3008 »
Hi Team,
Would it be possible to provide me with the part number of the lower and upper banjo bolts of the turbo ?
Also is the turbo pipe fixed or there is a soft curve on it ? (i think its number 14 from the diagram or 4).
Would it be possible to paste the diagram, so it can be more clear for me ?
Thanks in advanced,
x 1489
Martin3008 wrote: 09 Dec 2024, 19:08 Hi Team,
Thanks in advanced,
Here's the diagram:
Top bolt: 037655 £10.90
Bottom bolt: 037660 £11.89
Copper washers: 1682802280 £3.32 (might be each, or a bag of 4....!)
It does look like the oil pipe has a flexi section in it.
x 5672
myglaren wrote: 06 Dec 2024, 21:22 Scratch that, probably not up to the job.
The Amazon one is actually from ECP, so there's another worry.
Got one from GSF. Just been delivered, fitted and working as it should.
No more expensive than ECP (£120).
Huskyxantia
x 909
Unread post by Huskyxantia »
Hi Marc or Richard , VF7**************[VIN obfuscated, can be read by forum staff] needing part number(s) for the brake flexi hoses on the front . Thanks .
:-D
x 1489
Huskyxantia wrote: 11 Dec 2024, 22:13 Hi Marc or Richard , VF7**************[VIN obfuscated, can be read by forum staff] needing part number(s) for the brake flexi hoses on the front . Thanks .
Not handed, Original 4806G1 @ £67.45 each' cheaper for older cars 1650841880 @ £27.17 each
Huskyxantia
x 909
Thank you Richard .
:-D
PaulC5
x 689
Unread post by PaulC5 »
Please could you provide the part numbers for the front and rear wiper blades on our 2019 308sw, VIN VF3**************[VIN obfuscated, can be read by forum staff]
Thank you.
x 6945
There's an error in your VIN Paul (check the last 8 for sure).
x 1939
The RH front DRL of our 308 isn't working. I'm hoping that once I empty the water out and clean up the internals it'll work again but in the possibility probability that it won't could I have the part number please?
Are they handed at all?
x 6945
They only list the one (no left or right) Paul and you only have item (1) on the diagram on your vehicle:
(1)Front Lamp LED, part 9802795580, £155.69
x 1939
GiveMeABreak wrote: 18 Dec 2024, 12:40£155.69
:shock: :shock: :shock: :rofl2:
What other vehicles was it fitted to?
EDIT
According to an Ebay vendor they are also fitted to:
Citroën Berlingo B9 2008-2020
Citroën Berlingo Multispace B9 2008-2020
Citroën C-Elysee 2016-2020
Citroën C1 2005-2020
Citroën C3 MK2 MK3 2009-2020
Citroën C3 Picasso 2013~up
Peugeot 107 2012-2014
Peugeot 108 2014-2020
Peugeot 308 MK2 LB 2013-2020
Peugeot Grad Raid 2008-2020
Peugeot Partner 2008-2020
Peugeot Partner Tepee 2008-2020
Peugeot Ranch 2008-2020
Toyota Aygo 2005-2020
Does this ring true? If so, a larger pool of S/H ones has opened up.
PaulC5
x 689
GiveMeABreak wrote: 18 Dec 2024, 12:04 There's an error in your VIN Paul (check the last 8 for sure).
Sorry Marc, I misread an S after the K for a 5 so the correct VIN is VF3**************[VIN obfuscated, can be read by forum staff]
So please could you provide the part numbers for the front and rear wiper blades for our 2019 308SW, many thanks and sorry I wasted your time earlier.
x 6945
Will do, not at my rig at present, so will sort this for you shortly.
Huskyxantia
x 909
Needing to check these out , is there any possible part numbers for these
Each joint on the fluid line has them ( so ive seen,heard,read about )
Photo to show what i mean. Many thanks
Part needed for c3 picasso
:-D
x 6945
Haven't got a clue what you are referring to. That looks more like a pressure washer lance.
