Martin3008
Hi Team,
Would it be possible to provide me with the part number of the lower and upper banjo bolts of the turbo ?
Also is the turbo pipe fixed or there is a soft curve on it ? (i think its number 14 from the diagram or 4).
Would it be possible to paste the diagram, so it can be more clear for me ?
Thanks in advanced,
Thanks in advanced,
- x 1498
Here's the diagram:Martin3008 wrote: 09 Dec 2024, 19:08 Hi Team,
Thanks in advanced,
Top bolt: 037655 £10.90
Bottom bolt: 037660 £11.89
Copper washers: 1682802280 £3.32 (might be each, or a bag of 4....!)
It does look like the oil pipe has a flexi section in it.
- x 5678
Got one from GSF. Just been delivered, fitted and working as it should.myglaren wrote: 06 Dec 2024, 21:22 Scratch that, probably not up to the job.
The Amazon one is actually from ECP, so there's another worry.
No more expensive than ECP (£120).
Huskyxantia
- x 928
Hi Marc or Richard , VF7**************[VIN obfuscated, can be read by forum staff] needing part number(s) for the brake flexi hoses on the front . Thanks .
Husky.
- x 1498
Not handed, Original 4806G1 @ £67.45 each' cheaper for older cars 1650841880 @ £27.17 eachHuskyxantia wrote: 11 Dec 2024, 22:13 Hi Marc or Richard , VF7**************[VIN obfuscated, can be read by forum staff] needing part number(s) for the brake flexi hoses on the front . Thanks .
Huskyxantia
- x 928
Thank you Richard .
Husky.
PaulC5
- x 705
Please could you provide the part numbers for the front and rear wiper blades on our 2019 308sw, VIN VF3**************[VIN obfuscated, can be read by forum staff]
Thank you.
Thank you.
- x 6948
There's an error in your VIN Paul (check the last 8 for sure).
- x 1945
The RH front DRL of our 308 isn't working. I'm hoping that once I empty the water out and clean up the internals it'll work again but in the possibility probability that it won't could I have the part number please?
Are they handed at all?
- x 6948
They only list the one (no left or right) Paul and you only have item (1) on the diagram on your vehicle:
(1)Front Lamp LED, part 9802795580, £155.69
- x 1945
What other vehicles was it fitted to?
EDIT
According to an Ebay vendor they are also fitted to:
Citroën Berlingo B9 2008-2020
Citroën Berlingo Multispace B9 2008-2020
Citroën C-Elysee 2016-2020
Citroën C1 2005-2020
Citroën C3 MK2 MK3 2009-2020
Citroën C3 Picasso 2013~up
Peugeot 107 2012-2014
Peugeot 108 2014-2020
Peugeot 308 MK2 LB 2013-2020
Peugeot Grad Raid 2008-2020
Peugeot Partner 2008-2020
Peugeot Partner Tepee 2008-2020
Peugeot Ranch 2008-2020
Toyota Aygo 2005-2020
Does this ring true? If so, a larger pool of S/H ones has opened up.
PaulC5
- x 705
Sorry Marc, I misread an S after the K for a 5 so the correct VIN is VF3**************[VIN obfuscated, can be read by forum staff]GiveMeABreak wrote: 18 Dec 2024, 12:04 There's an error in your VIN Paul (check the last 8 for sure).
So please could you provide the part numbers for the front and rear wiper blades for our 2019 308SW, many thanks and sorry I wasted your time earlier.
- x 6948
Will do, not at my rig at present, so will sort this for you shortly.
Huskyxantia
- x 928
Needing to check these out , is there any possible part numbers for these
Each joint on the fluid line has them ( so ive seen,heard,read about )
Photo to show what i mean. Many thanks
Husky.
- x 6948
Haven't got a clue what you are referring to. That looks more like a pressure washer lance.
