Ok thanks for the heads up, i'll double check in advanceGiveMeABreak wrote: 05 Mar 2024, 10:57 Ok, but be mindful they may charge you diagnostic time to do this.
What DS5 Head Unit is this?
Peppazot
Re: What DS5 Head Unit is this?
Tekguy78
HI I have recently Rejoined the world of Citroen and Love my DS5
Im looking to find out some info about my car Like what model is the radio
any and all help much appriecated
- x 6956
We'll need the VIN for that as there are different systems installed. Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
Tekguy78
HI Thank you
My VIN is VF7**************[VIN obfuscated, can be read by forum staff]
My Headunit code is
Unit ref - 9806710580
CD number - 8980
SW version RNEG2.86.B1
Car also shows when the radio is on right driver display says radio off
and I cannot change the Fuel readout to mpg
Can you advise the full spec of the car I.E if it has wireless entry.
My Headunit code is
CD number - 8980
Tekguy78
Hey
Is there any info on my stereo model. I would love to upgrade the unit to the touchscreen model
- x 6956
You have an RT6 unit fitted. If you want a factory build sheet, you'll have to upgrade your membership (see below) as we have to pay for access to this data:
We can help if you need an original genuine part number, part diagram or vehicle factory build sheet and can't already find the info you need on the Forum. For this service, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future part number requests for up to 3 years, so excellent value.
If interested, links are below, then provide your vehicle's VIN in full, which will be masked automatically when you submit your post.
| A response to your question by a Forum Admin requiring parts or specific vehicle information requires you to have made a current contribution (Min. £10 / €11.48 or equivalent) to the Forum. |
Tekguy78
HI MarcGiveMeABreak wrote: 15 Dec 2024, 20:35 You have an RT6 unit fitted. If you want a factory build sheet, you'll have to upgrade your membership (see below) as we have to pay for access to this data:
to have made a current contribution (Min. £10 / €11.48 or equivalent) to the Forum.To Upgrade Your Membership & Donate Click Here
For Further Information About Vehicle Parts and VIN Numbers Click Here
I have donated and would love if its possible to get the build sheet. as i think a previous owner upgraded the Radio as mine has a few issues it reboots regularly and asks for a peugeot software update
- x 6956
Sure, here's your factory build sheet and as you can see you have the RT6 unit.
I personally won't advise on retrofits as there are factors that can affect the outcomes like vehicle electrical architecture compatibility and configuration changes that will need to be made. However Mac Slavko has upgraded his DS 5 and he has written a post about it here that you may find helpful:
RT6 to NAC (Connected NAV) Upgrade
| Vehicle Characteristics | |
| Vehicle family | DS 5 |
| AS/RP N° | 13318 89 2 0049 |
| Warranty Start Date | 30/05/2013 |
| Engine serial number | 10 DYZE 4081944 |
| OPB | 0017 |
| BER | e2*2007/46*0092*05 |
| P4A | 9803189999 |
| General Information | |
| PRODUCT TYPE | PASSENGER CAR |
| COMMERCIAL MARQUE/COMPONENT TYPE | DS |
| VEHICLE FAMILY | DS 5 |
| SILHOUETTE | 5 DOOR SALOON |
| TRIM LEVEL | HIGH MEDIUM |
| ENGINE | DW10CTED4 FAP TURBO DIESEL |
| TRANSMISSION | BVM6 |
| PAINT TYPE | THREE-LAYER PEARLESCENT METALLIC PAINT |
| BODY COLOUR | KWE - PEARLESCENT WHITE PAINT |
| INTERIOR TRIM TYPE | HALF-LEATHER DINAMICA "3I" |
| UPHOLSTERY COLOUR | "FZ" |
| GEARBOX (CHARACTERISTICS) | GBOX ML6 CL |
| ENGINE (TYPE) | EW/DW |
| Fuel Supply-Engine | |
| FUEL SUPPLY | DIRECT EXCHANGE TURBO INJECTION |
| DIESEL FILTER WATER DETECTOR | WITHOUT DIESEL FILTER WATER DETECTOR |
| CYLINDER BLOCK (MATERIAL) | CRANKCASE CAST IRON |
| FUEL | DIESEL GRADE DA/DE/DE+ |
| EMISSIONS STANDARD (ENGINE) | EURO 5 L6 UPPER ENGINE EMISSION CONTROL |
| CAPACITY | 2000 CM3 |
| OIL COOLER | MNTG WATER/OIL EXCHANGER ON ENGINE |
| FUEL TANK | FUEL TANK WITH LOCATING TAB |
| OPTIMISATION OF VEHICLE’S CONSUMPTION | NORMAL |
| CRANKCASE GAS CIRCUIT HEATING | WITH HEATER CASING GAS CIRCUIT |
| SPECIAL POWER TRAIN SOUND | WITHOUT POWER TRAIN TYPE |
| EOBD SELF-DIAGNOSIS SYSTEM | "EOBD" AUTO-DIAGNOSTIC WITHOUT ACCELEROMETER |
| VEHICLE TECHNICAL DEPOLLUTION | TECHNICAL VEHICLE EMISSION CONTROL EURO 5 |
| PARTICLE FILTER | WITH PARTICLE EMISSION FILTER |
| FAN | 1 AERO 2-SPEED 140W FAN WITHOUT SCOOP |
| FUEL VAPOUR RETRIEVAL | WITHOUT PETROL VAPOUR RECUPERATION |
| INJECTION ASSOCIATED VARIANT | MOUNTING DELPHI |
| DRIVE TRAIN | INTERNAL COMBUSTION DRIVE TRAIN |
| TANK FILTER | RESERVOIR FILTER INTERIOR |
| STOP AND START | WITHOUT STOP AND START |
| Gearbox Transmission | |
| FINAL DRIVE RATIO | REAR AXLE HYPOID GEARSET 17 X 71 |
| WHEEL STYLE | CANAVERAL 18-INCH WHEEL |
| CLUTCH | HYDRAULIC CLUTCH |
| DIFFERENTIAL (GEARBOX) | DIFFERENTIAL DIAMETER 86 |
| RIM/TYRE SIZE | 18 INCH TYRE FITMENT |
| TYRE (SIZE, TYPE) | 235/45 R18 98W REINFORCED TYRE |
| WHEELS FITTED | 8 INCH WHEEL |
| WHEEL (TYPE) | ALLOY WHEEL ASSEMBLY 2 |
| INFLATION PRESSURE LOSS INDICATOR | WITHOUT TYRE DEFLATION INDICATOR |
| GEARBOX TYPE | ML6C |
| Suspension-Steering-Brakes | |
| ABS | WITH ABS BRAKES |
| REAR ANTI-ROLL BAR | REAR ANTI ROLL BAR DIAM 27 |
| FRONT ANTI-ROLL BAR | FRONT ANTI ROLL BAR DIAM 23,5 |
| SUSPENSION | NORMAL SUSPENSION |
| DYNAMIC STABILITY CONTROL SYSTEM | ELECTRONIC STABILITY PROGRAM |
| BRAKE ASSOCIATED VARIANT | BOSCH 8.1 ESP |
| PEDAL BRACKET (TYPE) | PEDAL STANDARD |
| Body Fittings | |
| TOWBAR | WITHOUT TOWBAR |
| HORNS | HORNS-HARMONY |
| AERIAL | AERIAL + GSM + GPS |
| REAR SPOILER | WITH TAILGATE UPPER SPOILER |
| SIDE MOULDINGS (TYPE) | CHROME SIDE PROTECTORS |
| SIDE MOULDINGS (DIMENSION) | THIN LAT PROTECTORS+CHROME SILLS |
| WHEEL EMBELLISHER (STYLE) | CABOCHON HUB COVER |
| UNDERBODY SHIELD | WITHOUT PROTECTION UNDER BODY |
| INDICATORS | SIDE MARKER LIGHTS |
| SILL ILLUMINATION LAMP | WITHOUT SILL ILLUMINATION |
| ADDITIONAL SHIELD (UNDER ENGINE) | W/O ENGINE UNDERSHELDING |
| EXT. LOAD RETENTION RING (ATTACHMENT) | BOAT + LORRY EXT LASHING RING |
| EXT. REARVIEW MIRROR COMP. FUNCTION | EXT MIRROR ELECTRIC-FOLD BACK |
| ENGINE BAY SOUNDPROOFING | BULKHEAD SOUNDPROOFING + BONNET + SHORT ACOUSTIC POWER TRAIN |
| WINDSCREEN WIPER | FRONT WIPER BLADE WITH RAIN SENSOR |
| HEADLAMP WIPER | W/O HEADLAMP WIPER |
| FRONT PANEL BLANK | WITHOUT FRONT BUMPER PLUG |
| ROOF GLASS | WITH FIXED ROOF GLASS |
| BUMPER | FR/RR BUMPER STD BODY-COLOURED |
| MUDFLAP | WITHOUT MUD FLAPS |
| FRONT FOGLAMP | FOG LAMPS WITH CORNERING LIGHT |
| SPECIAL HEADLAMP (DOUBLE OPTIC) | TWO-TONE MASK |
| SPARE WHEEL | WITHOUT SPARE WHEEL |
| EXTERIOR ACCESSORIES | CHROME+BODY-COLOURED EXT HANDLE |
| BUMPER TRIM | BRILL BLACK FR BUMPER STRIP + RR NEUTRAL |
| GLASS (APPEARANCE) | FR TINTED WINDOW+DEEPTINTED RR (QUARTER+TAILGATE) |
| HANDS FREE ACCESS AND STARTING | WITH HANDS-FREE ACCESS/STARTING |
| Interior Fittings | |
| ANTI-THEFT ALARM | WITH THEFT PROTECTION ALARM |
| CIGAR LIGHTER | FRONT CIGAR-LIGHTER |
| REAR HEAD RESTRAINT | REAR HEADREST ADJUSTABLE |
| FRONT HEAD RESTRAINT | JOINTED FRONT HEADREST |
| BLIND SPOT DETECTION | WITHOUT BLIND SPOT MONITORING |
| FRONT SEATBELT | DOUBLE PYROTECHNIC SEAT BELT WITH ALARM |
| CLIMATE (AMBIENT TEMP) | TEMPERATE COUNTRIES |
| AIR CONDITIONING | WITH AUTO RECIRCULATION HEATER MATRIX |
| SPEED GRADUATIONS | SPEED GRADUATION IN MPH |
| DRIVING POSITION | RIGHT HAND DRIVE |
| ADDITIONAL HEATING | WITHOUT ADDITIONNAL HEATING |
| DASHBOARD EQUIPMENT | DASHBOARD + SLUSH VISOR |
| MISC. INT. LAMPS | SOFT AMBIANCE LIGHTING |
| LOAD SPACE TRIM | BOOT CARPET MAT |
| INSTRUMENT PANEL (CHARACTERISTICS) | GRADUATION 260 KM/H 160 M/H COLOUR MATRIX |
| DOOR TRIM | STANDARD |
| LOUDSPEAKER | 4 FR SPEAKERS (2 TW + 2 FR) + 2 RR SPEAKERS |
| DRIVER SEAT CONTROL | DRIVERS FRT SEAT MANUAL CNTROL |
| FRONT PASSENGER SEAT CONTROL | PASSENGER FRT SEAT MANUAL CNTR |
| FRONT PASSENGER SEAT ADJUSTMENT | PASSENGER TILTING BACK |
| COMPACT DISC | WITHOUT COMPACT DISC |
| SATELLITE NAVIGATION SYSTEM | WITH NAVIGATION SYSTEM + TRAFFIC INFO |
| HEADLAMP BULBS | HALOGEN BULB |
| TRAFFIC INFORMATION READER | WITHOUT LATERAL TRAJECTORY MONITORING |
| DISPLAY | DISPLAY DG4 |
| CLOCK | ANALOGUE CLOCK |
| FOOTREST | DRIVER’S FOOTREST |
| HEATING ELEMENT | NON HEATED SEAT |
| FRONT LATERAL AIRBAG | THORAX SIDE + CURTAIN AIRBAG |
| FOOTWELL LIGHTING | DRIVER’S + FRONT PASS’S FOOTWELL LIGHTING |
| EXTERIOR REAR VIEW MIRROR (HEATED) | EXT HEATING REAR VIEW MIRROR |
| AIRBAG DEACTIVATION | MANUAL AIRBAG DEACTIVATION |
| HEADLAMP HEIGHT ADJUSTER | REMOTE MANUAL HEADLAMP ADJUSTMENT |
| DIRECTIONAL HEADLAMP | WITHOUT DIRECTIONAL LIGHTS |
| WIFI | WITHOUT WIFI |
| RADIO RECEIVER | RT6 RADIO TEL-DIGITAL REMOTE DISPLAY |
| REFRIGERATION | AUTOMATIC AIR CONDITIONING |
| CARPET COVER | W/O CARPETMAT |
| LOAD SPACE STORAGE | WITHOUT STORAGE COMPARTMENT IN BOOT |
| COOLANT LEVEL WARNING LAMP | NO WATER LEVEL WARNING |
| OBSTACLE DETECTION SYSTEM | OBSTACLE DETECTOR CAMERA |
| TRIM ADAPTATION | CHROME KNOB + PVC GAITER |
| FLOOR MAT | W/O CARPETMAT |
| EQUALISER AMPLIFIER | WITHOUT EQUALISER AMPLIFIER |
| RADIO FREQUENCY | WESTERN EUROPE RADIO FREQUENCY |
| LOCKING CONTROL | CENTRAL DEADLOCKING + AUTOMATIC LOCKING |
| STEERING WHEEL | 4 BRANCH LEATHER STEER WHEEL DECOR METAL |
| AUDIO PACK AUXILIARY SOCKET | 1 JACK SOCKET + USB |
| TELEMATIC UNIT | WITHOUT TELEMATIC UNIT |
| Electrical | |
| ALTERNATOR | ALTERNATOR 150 AMP |
| BATTERY | BATTERY L3 720 LDC**************[VIN obfuscated, can be read by forum staff] |
| STARTER MOTOR | STARTER MOTOR CL 5 |
| SPECIAL LIGHTING | AUTOMATIC HEADLAMP ILLUMINATION |
| CEN. LOCKING REM CONTROL FREQUENCY | 433.92 MHZ SUPER HETERODYNE |
| BATTERY CHARGE MEASUREMENT | WITH BATTERY CHARGE MEASUREMENT |
| LIGHTING OF LAMPS | AUTOMATIC SWITCHING ON OF LIGHTS |
| Component Manufacturers | |
| Miscellaneous | |
| SPECIAL SPECIFICATION | STANDARD |
| ATMOSPHERIC CONDITIONS | NORMAL ATMOSPHERE |
| VIN PLATE | EUROPEAN UNION CONSTRUCTOR’S PLATE + NRE |
| LABEL | WITHOUT LABEL |
| RADIO HEADPHONE SOCKET | WITH ACCESSORIES SOCKET |
| TRAFFIC SIDE | DRIVING ON THE LEFT-HAND SIDE |
| SIDE IMPACTS | STANDARD SIDE BUMPERS |
| EMERGENCY EQUIPMENT | PUNCTURE REPAIR KIT |
| SURFACE CONDITIONS | GOOD TERRAIN |
