Black smoke
991hughes
Black smoke
Unread post by 991hughes »
Hi still having issues with black smoke fitted new pcv valve new dpf new maf sensor serviced can't find no air leaks anybody got any other ideas driving me crazy no codes in ecu egr seems to be working OK on live data anybody had issues with turbo seals passing oil
andyandjulie
x 14
Re: Black smoke
Unread post by andyandjulie »
Hmm, had an issue with a turbo on a Nissan 300ZX (petrol) leaking oil on the over run, the smoke was very white.. Not sure if that's much help. Do you know if the car has had any ECU enhancements?
x 3277
Re: Black smoke
If you don't mind me asking, have you checked for any restrictions/blockages in the air intake path? Black smoke is, I believe, an indicator of poorly burnt fuel, usually (but certainly not always) caused by a reduced air intake.
x 1971
Re: Black smoke
Unread post by Stickyfinger »
With a HDi I would be VERY concerned that the black smoke (normally due to over fuelling/it not being burnt) was both diluting the engine oil rapidly and damaging the DPF.
I would NOT drive a DPF equipped car for those two reasons............leaky injectors would be my first point of suspicion, these should be removed and put on a tester I would think.
Note: IF it were oil getting past the turbo seals and assuming combustion was correct, that smoke would be white/grey.....also, IF it were the case this was happening then the risk of turbo runaway would be very high, that would kill the engine and is another reason (even if I think it is not the problem) to NOT drive the car untill the problem if found.
991hughes
Re: Black smoke
Thanks for the replys I have found today in live data the absolute throttle postion is showing 100% constantly at idle and when driving stays at 100% is this normal or should the reading change as the accelatror is increased or decreased many thanks once again
