Hi
I’m new here but would like anyone with any experience of the sort of problem with my c4 ehdi
1.6 semi auto . The problem is when I turn the ignition on the headlights come on without using the stalk as do the wipers also the dash screen is completely blank the heater doesn’t work the indicator s don’t work but the hazards do , I did have the rac man out who tested all the fuses but couldn’t get the car to start so any advice would be gladly appreciated . I did remove the radio to see if it had Bluetooth so I don’t know if I’ve disturbed a connection behind
C4 wierd electrical issue
PaulC5
- x 685
Re: C4 wierd electrical issue
Could be a flat battery. Cars can give odd electrical apparent faults when the battery is flat. Our C5 puts headlights on and the wipers move as an example.
- x 1052
I'd be amazed (and very worried) if the RAC patrol never ruled out a basic thing like the battery before even checking the fuses.
Mal9876
OK thanks for the replies I did manage to sort it in the end there where two bare wires coming from the radio wiring loom that must have shorted out I rechecked the f8 fuse in the glove compartment and sure enough it was broken , replaced fuse and all is well
had me worried there for a mo
Mal9876
Quick edit meant to say fuse not duce
