GIOCAR99
Unread post by GIOCAR99 »
Hi I need the number part of Daytime Running Light Right Led For Ds3 2021 and part number of Right posterior door handle
Many thanks
Ds3 Crossback Puretech 130 Automatic Performance Line 2021
x 6945
Rhothgar wrote: 25 Nov 2024, 17:35 Evening!
Please could I have the relevant part number for the heater blower resistor (rheostat) for the 3008?
Intermittent issue with her blower motor which has the potential to fail probably at the worst time of year anytime soon. No air this morning and then only on full (allegedly) but seems alright to me this evening. Very odd.
(6) Heater Motor Control Module, part: 6441CQ, £215.62
x 6945
GIOCAR99 wrote: 26 Nov 2024, 08:50 Hi I need the number part of Daytime Running Light Right Led For Ds3 2021 and part number of Right posterior door handle
Many thanks
You haven't provided the VIN!
x 1491
GiveMeABreak wrote: 26 Nov 2024, 09:51
Many thanks
It's here Marc (I'd look it up, but at work...!) viewtopic.php?t=84325
x 6945
Ok, thanks Richard. I'll sort it. :wink:
(1) Front Lamp, Right, part: 9820841180, £319.40
Rear Door Opening Control (Right), part: 98250375DX, £355.93
Dustysweeper
x 20
Unread post by Dustysweeper »
Well after finally getting my Eolys issue sorted yesterday, today some moron decided to get themselves chased from the police and side swiped my driver side mirror clean off.
Could I please have the part number for the complete driver side mirror.
Many thanks.
x 6945
Sorry to hear that, what a scumbag. It happened to me once too - but in my case just a dopey sod that shouldn't of been on the road any more.
(1) Exterior Mirror Right, part: 1610546180, £588.56 8-[
Have a look at the diagram, as there are other parts that are replaceable if the damage isn't total.
These are usually sold primed, so will have to be painted, same with any aftermarket one you can find.
GORAX
x 14
Unread post by GORAX »
Hello everyone According to the FAP app, the 2nd stage of the cooling relay does not work. what exactly do I have to replace?
GOOGLE TRANSLATE
Dunkah
x 11
Unread post by Dunkah »
Hi Marc
Part number request please.
Need a part number for the door seal, right front on a c4, vin VF7**************[VIN obfuscated, can be read by forum staff]
Particularly the outer door seal, the one that’s attached to the door rather than the inner one attached to the body.
Many thanks
x 6945
This one?
(8) Lower Door Seal (Right), part: 9025CQ, £76.39
x 6945
GORAX wrote: 29 Nov 2024, 20:03 Hello everyone According to the FAP app, the 2nd stage of the cooling relay does not work. what exactly do I have to replace?
This is just the parts thread, we don't deal with technical issues here, but if you require the cooling fan electronic control module then it is:
(2) Cooling Fan Electronic Control Module, part: 9847019780, £89.10
GORAX
x 14
Thanks Marc
GOOGLE TRANSLATE
GIOCAR99
GiveMeABreak wrote: 26 Nov 2024, 10:09 Ok, thanks Richard. I'll sort it. :wink:
Hi there, thanks for your answer.
I have found both 9820841180 and 9843691480 as right DLR for my ds3.
Do you know by any chance what's the difference between the two codes? are they both ok?
x 6945
That's not coming up as a valid part for this vehicle. I can only provide you with the official DS part and the correct one is 9820841180 as stated. There are different build dates and model versions, so I would not take a chance and stick to the official part provided to you.
Huskyxantia
x 918
Unread post by Huskyxantia »
VF7**************[VIN obfuscated, can be read by forum staff] hi marc im back again need the part number for clutch pedal . Is it clutch & break pedal box ? My mechanic has found the problem why mine keeps killing master cylinders. Thanks marc.
:-D
