DPF regenerates often
lubics
Unread post by lubics »
Hello!
The problem with my car is that the particulate filter regenerates every 50 kilometers. (The problem has been going on for months.) The particulate filter, the EGR valve, and the particulate filter sensors have already been replaced. There was also a software update, but the error remains. I have been to several car services (including Citroën specific service), but they cannot solve the problem.
Does anyone have an idea what the solution could be?
Car type: Citroën C5 Aircross, 1499 cm3, BlueHDI, automatic transmission, 2019
Thank you very much!
György Lubics
Hungary
x 1938
Re: DPF regenerates often
Do you have any error codes from the car using a high spec diagnostic machine (preferably Diagbox)?
lubics
Unfortunately, I don't have a diagnostic device. According to the car mechanics, the system doesn't write a specific error code that clearly identifies the problem. For example, it indicates an environmental error or an error code indicating engine oil dilution.
x 1938
Have the mechanics not put a code reader onto the car?
lubics
yes, that code reader wrote these non-specific codes (as far as I know). I don't know exactly what number or code the system indicated, but based on them the mechanics were unable to identify the source of the problem.
x 1938
Those codes are important. Can you get the precise readings off the mechanics?
PaulC5
x 675
Unread post by PaulC5 »
When the particulate filter was replaced did you do a diagnostic to tell the car it had been replaced ? I could be wrong but I think this is needed or the car will continue to think it has the old blocked filter.
x 6956
That is correct, if the engine ECU has not been told the particle filter has been replaced it will not know. Still, very strange that this has needed a replacement for a 2019 vehicle unless you frequently drive to the moon and back.
tricoloured
x 14
Unread post by tricoloured »
Hi
I had a similar issue with my 2018 Expert 2.0Hdi regenerating every 45 miles or so but everything else seemed ok, I read something somewhere on a Peugeot/Citroen forum that made me think it could be injector related.
Not many miles later I ended up changing the injectors and the fuel pump due to a missing fuel filter (another tedious story), anyway after that active regenerations were up to a minimum of about 450 miles with local very short journeys but usually much less frequent.
Don't know if this is relevant to your situation but I though it was worth sharing anyway.
Regards
Bobby
lubics
Paul-R wrote: 28 Nov 2024, 11:09 Those codes are important. Can you get the precise readings off the mechanics?
Thanks, I'll try to ask my mechanic.
lubics
GiveMeABreak wrote: 28 Nov 2024, 14:19 That is correct, if the engine ECU has not been told the particle filter has been replaced it will not know. Still, very strange that this has needed a replacement for a 2019 vehicle unless you frequently drive to the moon and back.
My first post wasn't precise, the filter was not replaced, only cleaned. Im not sure, if the engine was told about this, I'll have the ask my mechanic. The thing is, when the filter was picked apart I was told it wasn't blocked, but it was still regenerating for some reason.
lubics
tricoloured wrote: 28 Nov 2024, 21:15 Hi
Regards
Bobby
Thank for the tip, I'll look into it, if the other solutions don't work.
x 6956
lubics wrote: 29 Nov 2024, 14:01
This is still required even if cleaned - otherwise the ECU will not know this.
