Update Sat Nav
Huskyxantia
- x 829
Update Sat Nav
How do you update the sat nav ?
Reason: Moved to a separate thread
Husky.
- x 1905
Re: Update Sat Nav
MyWay/RNEG or eMyWay/RNEG2/RT6?
Huskyxantia
- x 829
Re: Update Sat Nav
Mines a 2010 308cc rt6 version
Husky.
- x 1905
Re: Update Sat Nav
Check your PM for maps.
Or do you mean update the firmware?
AaronS99
Re: Update Sat Nav
Does anyone have the firmware update link for the
Peugeot 5008 Allure HDi please?
Currsnt details below
Unit Reference: 9808377777
CD number: 8785
SW Version RNEG2.80.E.2
CD number: 8785
- x 1905
Re: Update Sat Nav
I have 2.85 and 2.86 as ISOs and 2.86 as software for a USB stick. If you post which one(s) you want I can PM you a link.AaronS99 wrote: 20 Oct 2023, 19:10 Does anyone have the firmware update link for the
CD number: 8785
Huskyxantia
- x 829
Re: MyWay/RNEG to eMyWay/RNEG2/RT6 upgrade
Sorry ive only just seen this, firmware , would mine be able to be updated with maps , firmware or both ?
Husky.
- x 1905
Whoof, that's a bit of a delay in replying!Huskyxantia wrote: 17 Nov 2024, 22:05Sorry ive only just seen this, firmware , would mine be able to be updated with maps , firmware or both ?
As far as I can see there's no reason you can't do both, although not in a single update. They're two different things. See a few posts above for what I have in firmware although I would caution against unnecessary updating if you're not having any problems. Are you having problems? What version of firmware is currently fitted?
I can also assist with map updates. See the PM I sent you a year ago.
EDIT
Belay that. The PM refers to RNeg rather than RNeg2/RT6 updates. I'll have to PM you the proper details but let's get the firmware issue out of the way first.
Huskyxantia
- x 829
[/quote]
Ok, thanks ,its working ok, but theres been a few new roads since the car was built seeing the red arrow going in space is fun ! Its still git its original sd card so it can roll back to that i guess if needs be ?
[/quote]
Husky.
- x 1905
Re: Update Sat Nav
When you say the SD card do you mean an internally fitted one or one that pushes into a slot just below the large centre knob?
Huskyxantia
- x 829
Re: Update Sat Nav
One that pushes into the slot
Husky.
Huskyxantia
- x 829
Re: Update Sat Nav
So my setup is sd card under control dial push in .
Husky.
- x 1905
Re: Update Sat Nav
OK. Then in that case it's not an RNeg2/RT6 unit but an RNeg unit. I don't have personal experience of the RNeg system unfortunately but what I wrote in the PM is correct.
I also don't have any firmware files for RNeg units but I would still caution against needless updating.
Stijn
- x 3
Re: Update Sat Nav
i'm am not aware of the firmware updates for the RNEG but it looks like there is a new 2024 map on SD for the RNEG. To my suprise to be honest. Last time i checked there was only a 2014 map.
Huskyxantia
- x 829
Re: Update Sat Nav
Looks like my nav will be drifting through space when new roads are driven on then .
Husky.
