P2463 P246C
GORAX
- x 14
GORAX
- x 14
Re: P2463 P246C
Today I did a regeneration. Was done with Diagbox. Unfortunately, success anyway. In the end Diagbox said exhaust heat not reached. There was a brief burst of blue smoke for a few minutes that smelled like it had been burnt. is this particle filter completely defective?
GOOGLE TRANSLATE
GORAX
- x 14
Re: P2463 P246C
So DPF is completely clean. But after installation diagbox brings again error exhaust heat not reached. Where do I have to look further?
GOOGLE TRANSLATE
GORAX
- x 14
Re: P2463 P246C
could it be that the regeneration is not started because adblue and nox are deactivated?
I still have to get the adblue tank, but I can install the NOX sensor now so that it can regenerate again.
GOOGLE TRANSLATE
GORAX
- x 14
Re: P2463 P246C
Adblue and nox are activated. Works Fine. But Regeneration doesnt still work. Exhaust does not get warmer than 350 degrees. where do I have to look further?
GOOGLE TRANSLATE
GORAX
- x 14
GORAX
- x 14
GORAX
- x 14
- x 1941
Re: P2463 P246C
Good to hear. How much did it cost you?
GORAX
- x 14
