x 1478
GORAX wrote: 15 Nov 2024, 20:08
RichardW wrote: 15 Nov 2024, 19:56
GORAX wrote: 15 Nov 2024, 19:00
Thanks. Is this Ok for me? 9807279280
VF7**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]
That's the seal on the adblue injector? Sorry, I only looked at the main exhaust joints which have no seals.
It says there is a seal between the catalytic converter and the exhaust pipe. So the front part in front of the DPF.
Here's the diagram, nothing showing
x 1478
earlsgate wrote: 15 Nov 2024, 20:00 sorry thought these were kept on record
boxer vin VF3**************[VIN obfuscated, can be read by forum staff]
Marc keeps a list, but I'm not that organised and he's off line as the vermin has chewed his internet cable again!
Romtag
x 8
Unread post by Romtag »
Hi guys,
The exhaust clamp on my 308 sw just behind the dpf has broken.
Could I please get part number and size so I can order a replacement as I can see 61 and 67mm parts 🤦???
Mark
Owner of a 2013 308 SW
x 1478
Assuming it's 1.6 HDi it's probably 66mm, part number 1692647380 (which replaces 171366) - it's £11.90 from PSA. Post up the VIN and I will confirm this is correct.
x 6954
RichardW wrote: 15 Nov 2024, 22:22 Marc keeps a list, but I'm not that organised and he's off line as the vermin has chewed his internet cable again!
Thanks for covering Richard - There's now a major outage in the area, so we have no fixed date for service - I expect it's because of the replacement fibre they're having to lay. The Mini EE backup WiFi Hub we have is really poor so keeps disconnecting, so I've not really been online.
GORAX
x 14
Unread post by GORAX »
Hi togehter,
Does my car have an exhaust temperature sensor?
GOOGLE TRANSLATE
x 1478
I think item 3 in this picture?
£219.62 in the UK. There was a thread about this unit recently, where the sensors were swapped over or something.
x 2310
Unread post by MattBLancs »
Evening all,
Hopefully an easy one:
Grey 308 SW
Can you confirm the key battery size?
CR1620?
That's what in it currently, I'm only asking as the other 308 had the wrong cell in its key! (Right diameter but too thin! Intermittent behaviour as a result!)
EDIT: Ignore the above, checked the handbook: CR1620 is correct :)
Thanks,
Matt
x 1478
It does appear to reference 1620 - they want to relieve you of over £15 though, so I'd go elsewhere!!
Huskyxantia
x 856
Unread post by Huskyxantia »
Huskyxantia wrote: 13 Nov 2024, 14:52
Huskyxantia wrote: 13 Nov 2024, 08:18 VF7**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff] oil pump part number requied please Marc
Many thanks.
I've reposted the vin just to make sure its the correct one
VF7**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff] its for the oil pump part number .
Hi marc , can i have the part numner for this oil pump, ive just had a rather snotty email from the supplier asking why i havnt confirmed the part number with them , the only reason i didnt is they marked it off as shipped as they did a check which they never bothered to let me know .. oh well , any ways , my vin is above , thanks again.
:-D
x 6954
Can you please type (or copy and paste) the actual VIN, - it's no good posting obfuscated VIN numbers, as all you are doing is pasting the mask! As you have multiple vehicles, I'm not sure which vehicle is applicable, so don't want to waste time as our Fibre is still out, so have a flakey connection.
Huskyxantia
x 856
Hi, its VF7**************[VIN obfuscated, can be read by forum staff] this is the one . C3 picasso , weve been down with our fibre to it drops come back on , open reach everywhere here lol cheers agaim
:-D
cncjeff1
Unread post by cncjeff1 »
Greetings All,
I have a 2016 Citroen Berlingo, VF7**************[VIN obfuscated, can be read by forum staff]. I need part numbers for the gearbox, clutch, and throw-out bearing. Thank You in advance.
Best Regards,
Jeffrey
x 6954
(1) OEM New Manual Gearbox, CP 17X71, Marking (ETBC) ET23, part: 1609983380, £5667.26
Standard Exchange Gearbox, CP12X71, Marking ET23 (ETB3), part: 1611180180, £2909.90
OEM (1) Pro Clutch Kit, part: 1650400680, £574.05
Standard Exchange Clutch Kit, part: 1650403580, £473.11
Note: Outstanding Work (After-Sales Campaign) from 28/02/2021 is showing. Work will be free of charge, so contact your dealer.
HCJ - Timing belt
The operation involves replacing the timing front face parts
x 1478
Huskyxantia wrote: 20 Nov 2024, 13:59 Hi, its VF7**************[VIN obfuscated, can be read by forum staff] this is the one . C3 picasso , weve been down with our fibre to it drops come back on , open reach everywhere here lol cheers agaim
Appears you missed this.... :lol:
RichardW wrote: 15 Nov 2024, 18:42
Huskyxantia wrote: 13 Nov 2024, 08:18 VF7**************[VIN obfuscated, can be read by forum staff] oil pump part number requied please Marc
Many thanks.
1001 G8 £374.35
