moizeau
- x 429
More of a parts diagram request than a number so I can work out where an E clip goes please.
After knocking the windscreen spindle out and cleaning it I have this E clip left over. There is only 1 recess in the spindle and I was sure the C clip that retains the washer (that retains the O ring) uses it (photo). I remember taking it out but can't remember where from, maybe the recess but if so where does the C clip go?
This is the van Marc. Doing my head in now.
Cheers
Edit, Can't use the other side as a reference as that was dismantled to prove that the spingle comes out without removing the motor and all the gubbins
Cheers
Pete
- x 6956
Here Pete, there are washers referred to at (2) and captive washers at (71) & (73), but can't see the clip unless it is (2).....
- x 8085
Hope I'm not butting in but I'd suggest that the e clip may come from one of the rod joints I have circled in red here:
- x 6956
Looks good to me Mick
moizeau
- x 429
No Mick, they clip on and off. The diagram that Marc has put up is slightly different to mine. The spindle comes up through it's support then there's an O ring, then a flat washer, then a C clip. Guessing it must be part of an assembly.
Thanks for the diagram Marc, though non the wiser
Pete
Huskyxantia
- x 901
Many thanks Marc , & you have just settled a niggle ive always had with conversions to solid.
Husky.
508c5
- x 4
Hi,
Can i have the OE part number for the catalytic converter of a Citroen Picasso C4 with a VIN number - VF7**************[VIN obfuscated, can be read by forum staff]
THX
THX
Huskyxantia
- x 901
Hi marc, is there any other DMF numbers at all as im not having much luck at all ,i did find a solid one on ebay, but the bolt holes for the plate cover were not as many .. only 2 plus the seller is being very weird , scammer sort of weird. If theres any of nunbers that cross ref , id be greatful for you help.GiveMeABreak wrote: 10 Nov 2024, 13:33
(10) Dual Mass Flywheel, Diam 291 131 DTS OEM Valeo (Embray), part: 0532T2. £697.39.
Thanks.
Husky.
508c5
- x 4
try Bart-Ebben of the NetherlandsHuskyxantia wrote: 11 Nov 2024, 16:59Hi marc, is there any other DMF numbers at all as im not having much luck at all ,i did find a solid one on ebay, but the bolt holes for the plate cover were not as many .. only 2 plus the seller is being very weird , scammer sort of weird. If theres any of nunbers that cross ref , id be greatful for you help.GiveMeABreak wrote: 10 Nov 2024, 13:33
Thanks.
- x 6956
Autodoc have one listed here:
2 options here: https://www.autodoc.co.uk/car-parts/oem/0532t2
Amazon:
https://www.amazon.co.uk/Flywheel-Citro ... B0DBJ6T2Q2
Amazon:
GORAX
- x 14
Hello everyone,
I need the part number for a differential pressure sensor on my dpf.
GOOGLE TRANSLATE
- x 6956
(10) Catalytic Converter, part: 9803403380, £1444.79508c5 wrote: 11 Nov 2024, 16:24 Hi,
THX
- x 6956
(1) Differential Pressure Sensor, part: 1618Z9, £120.20GORAX wrote: 12 Nov 2024, 07:41 Hello everyone,
Huskyxantia
- x 901
VF7**************[VIN obfuscated, can be read by forum staff] oil pump part number requied please Marc
Many thanks.
Many thanks.
Husky.
stickery74
Thanks Marc, I am struggling to source one of these in any condition.
