moizeau
x 423
Unread post by moizeau »
More of a parts diagram request than a number so I can work out where an E clip goes please.
After knocking the windscreen spindle out and cleaning it I have this E clip left over. There is only 1 recess in the spindle and I was sure the C clip that retains the washer (that retains the O ring) uses it (photo). I remember taking it out but can't remember where from, maybe the recess but if so where does the C clip go?
This is the van Marc. Doing my head in now.
Cheers
Edit, Can't use the other side as a reference as that was dismantled to prove that the spingle comes out without removing the motor and all the gubbins
Pete
x 6947
Here Pete, there are washers referred to at (2) and captive washers at (71) & (73), but can't see the clip unless it is (2).....
x 8151
Hope I'm not butting in but I'd suggest that the e clip may come from one of the rod joints I have circled in red here:
Modified parts diag.
x 6947
Looks good to me Mick
moizeau
x 423
No Mick, they clip on and off. The diagram that Marc has put up is slightly different to mine. The spindle comes up through it's support then there's an O ring, then a flat washer, then a C clip. Guessing it must be part of an assembly.
Thanks for the diagram Marc, though non the wiser
Pete
Huskyxantia
x 927
Unread post by Huskyxantia »
Many thanks Marc , & you have just settled a niggle ive always had with conversions to solid.
:-D
508c5
x 4
Unread post by 508c5 »
Hi,
Can i have the OE part number for the catalytic converter of a Citroen Picasso C4 with a VIN number - VF7**************[VIN obfuscated, can be read by forum staff]
THX
Huskyxantia
x 927
GiveMeABreak wrote: 10 Nov 2024, 13:33 Image
(10) Dual Mass Flywheel, Diam 291 131 DTS OEM Valeo (Embray), part: 0532T2. £697.39.
Hi marc, is there any other DMF numbers at all as im not having much luck at all ,i did find a solid one on ebay, but the bolt holes for the plate cover were not as many .. only 2 plus the seller is being very weird , scammer sort of weird. If theres any of nunbers that cross ref , id be greatful for you help.
Thanks.
:-D
508c5
x 4
Huskyxantia wrote: 11 Nov 2024, 16:59
Thanks.
try Bart-Ebben of the Netherlands
x 6947
GORAX
x 14
Unread post by GORAX »
Hello everyone,
I need the part number for a differential pressure sensor on my dpf.
GOOGLE TRANSLATE
x 6947
508c5 wrote: 11 Nov 2024, 16:24 Hi,
THX
(10) Catalytic Converter, part: 9803403380, £1444.79
x 6947
GORAX wrote: 12 Nov 2024, 07:41 Hello everyone,
(1) Differential Pressure Sensor, part: 1618Z9, £120.20
Huskyxantia
x 927
VF7**************[VIN obfuscated, can be read by forum staff] oil pump part number requied please Marc
Many thanks.
:-D
stickery74
Unread post by stickery74 »
Thanks Marc, I am struggling to source one of these in any condition.
