Hi everyone,
I have a problem with my car. Today i have got lots of error code. ESP/ASR error, brake error etc. I start my car and the engine stuttler at idling
I read the error from my car and I would have liked to attach it ,but I did not know.
So I write the error code:
U1208
C1391
P16A3
P0262
Citroen Grand C4 Picasso 2012 1.6 e-HDI injector error
kalm007
kalm007
- x 1487
Re: Citroen Grand C4 Picasso 2012 1.6 e-HDI injector error
Likely it needs a new injector, common on this engine.
kalm007
Just I have to replace 1 injector or I have to replace all injector.
And according to error message the first injector is bad. So from left to right is the first.
- x 1487
You can probably get away with just changing the faulty one. No 1 is at the flywheel end, because the French like to be different!
kalm007
Is the flywheel side the first?
I thought that the first is where the diesel filter is
- x 1942
The fuel filter can theoretically be situated anywhere whereas the flywheel always has to be between the engine and gearbox. Go with the flywheel!
kalm007
Yes It is true
Thank you for the information about injector sequence. Really this is a french car
kalm007
Hi again!
I bought a new injector. I replaced but I have a new problem. Now the No1 cylinder is okay but the injector is too fast and the idling is not so good.
I wrote the new injector code into the car. So I dont no what is the problem. I chose the injector code via Servicebox with VIN number.
And later I got a new error code
P12A1.
P16A3
P12A1.
P16A3
kalm007
Ohh f***k I forgot inicializing the new injector. Only I wrote the new code. Now it is perfect.
Thank you everybody
Thank you everybody
