Hello all, I wanted to know if anyone can confirm the type of flare that the metal pipe ends have at the front.
I think the pipe size is 3/16" and the union nut is M10 thread. Just wonder if it is the DIN type of double flare.
Thanks, Graeme
Quick question about C5X7 front brake pipes
aerodynamica
- x 216
Graeme M
- x 6950
Re: Quick question about C5X7 front brake pipes
I can't advise you on this Graeme, sorry as this sort of data isn't generally available, so hopefully somebody else will know...
aerodynamica
- x 216
Thanks Marc, it's likely fairly standard but I'm used to old school hydraulic Citroens with the LHM type unions and pipe sizes. I am finding the suppliers of replacement copper pipes do not have X7 items. Probably because no one asks for them. So I'm hoping to make my own. I just would like to know what the pipe ends are like short of removing one of the original ones from the car. I'm certain the outer end is a DIN double flare type but hope someone actually knows. The inner end of the pipe however, might differ as it fits to the ABS block.
Graeme M
- x 2008
It is a Standard brake system..............vrs "normal" Citroen
European standard is the DIN Flair......
It is a ATE system....so again, I would hazard a punt of a few ££'s on DIN at both ends (Xantia is DIN between the ABS block and the flexi).
kantica
- x 10
4.75mm pipe, with M10x1 coupling union, DIN flare.
Pipes from master cylinder to the ABS block seem to be wider / or have bigger protective layer with M12x1 coupling. From ABS block to the flexible pipe its 4.75mm (3/16") standard size.
aerodynamica
- x 216
Thanks, could you confirm that the flare and nut are the same at the abs block end? Just to corroborate what Alasdair is saying.kantica wrote: 21 Oct 2024, 22:31 4.75mm pipe, with M10x1 coupling union, DIN flare.
Might take the chance that it is as we think anyway
Graeme M
kantica
- x 10
I am not sure about nut size at ABS block, but I am pretty sure flare is DIN.
