- x 6946
Parts thread now open for requests, although there may be some further disruptions.
biohead
Hi,
Please could I get a part no. for the BPGA on a 2017 DS5?
VIN is VF7**************[VIN obfuscated, can be read by forum staff]
Symptoms are as per this thread: viewtopic.php?t=73480 which gives part no. 9666851480, but for an older car, so just wanting to check.
- x 1496
9800223680 - £387.31
steveclv
- x 40
Hi
Can I get the part number for a High Pressure Fuel Pump for my 2009 C5 X7 2.0 Hdi 138 Auto please?
Steve
Steve
- x 6946
Here you go:
(1) New OEM Delphi Roissy High Pressure Pump, part: 1920LP, £1832.23
Standard Exchange HPP Delphi Roissy, part: 1921N3, £975.43
darbuck
- x 289
Hi Marc,
can you give me a part number for the clock spring Comms unit for my 508 the air bag squib is showing high resistance.
Vin VF3**************[VIN obfuscated, can be read by forum staff]
Darren
- x 6946
(1) Multifunction Control Unit, part: 98199434ZD, £602.26
Yewboy69
- x 3
Could I please have the part numbers for the engine ECU and BSI.
Many thanks in advance!
- x 2359
Good afternoon
Could you tell me the price for a bottom ball joint heat shield for the grey 308?
eBay seems to suggest 3623 13 could be the correct item. eBay also £17.99 each!? Autodoc has them listed to but out of stock (£4-£6 if they do come back in stock)
A pretty crusty mess of what's left of the two on this car!
Thanks as always!
Thanks as always!
darbuck
- x 289
- x 6946
Here you are MattMattBLancs wrote: 18 Oct 2024, 15:56 Good afternoon
Thanks as always!
(6) Ball Joint Protector, part: 362313, £6.05
508c5
- x 4
Hello
What is the OE part numbers for the front and rear breaking system (discs and pads) for a Citroen Picasso c4 (5 sitter) , 2018, 1.6 petrol with the vin number VF7**************[VIN obfuscated, can be read by forum staff]
Thx
Thx
- x 2359
Spot on, thank you!
- x 6946
Parts Request Service Back Up (for now anyway
Skull
- (Donor 2026)
- x 382
Hi Marc
VIN VF7**************[VIN obfuscated, can be read by forum staff]
Handbrake cable Part No and length if listed for my Xantia OSF please?
I'm guessing it's 1330mm for OSF
Cheers
Cheers
Gary
Gary
