Where is this leak coming from? (pictures and videos attached)
Fred Timperly
Unread post by Fred Timperly »
I noticed a puddle of oil on my under tray when I topped up my washer fluid. I’m not sure where the leak is coming from, but I’ve attached some pictures and a video to help identify it. Any advice would be appreciated!
x 1488
Re: Where is this leak coming from? (pictures and videos attached)
Could be hang over from oil change, or leak from the housing, or leak from the clutch slave cylinder? You'll need to get it cleaned off to see where it is coming from.
x 1072
Unread post by Rp0thejester »
I think the clue is in your second photo. Don't worry where it ends up just where it starts from. Has that cap been tightened correctly?
Fred Timperly
Rp0thejester wrote: 15 Oct 2024, 21:26 I think the clue is in your second photo. Don't worry where it ends up just where it starts from. Has that cap been tightened correctly?
Yes, it had a full service recently, including oil filter change.
