One for the Air Buffs
x 7163
Re: One for the Air Buffs
Thanks Matt. You have done well! Much appreciated :-D
x 8062
Can I get away with this on here? :-D
x 1054
Unread post by Rp0thejester »
I have to say I'm not a bus fan but WW2 aircraft is right up my street!! My fav being EP120 AEA Spit Mk5 with clipped wings, although it wasn't originally a clipped wing, it's the owners choice.
x 1054
There was a Constellation sitting there so.....okay
x 8062
If not, this one is real!! :-D
x 7163
mickthemaverick wrote: 08 Oct 2024, 19:45 Can I get away with this on here? :-D
Of course! There is plenty of scope to fill the thread up with a bit of content and an easy subject to join in with. If it lulls I'll even bring in Shag Eckford and his signature on the board at White Hart at Brasted into the fold.
x 1054
The video of that plane was good, the following video of idiots at work trapped me.
x 8062
Not sure what that was Ryan, Youtube generated presumably? :)
x 1054
I used to volunteer at Duxford doing restoration as a young man. So I was lucky enough to get to sit in all the WW2 aircraft. Everything from the Tigercat to the Spits, Mustangs etc, even got to sit in the Russian Hind helicopter, wow that's a sickly shade of green in the cockpit. Also I used to do the food in the pilots enclosure during flying legends so meet alot of pilots and got to go in alot of aircraft
x 8062
Is it the Concorde at Duxford that still has, allegedly, Brian Trubshaw's hat trapped in the expansion joint? :)
x 1054
All I can tell you about that Concorde at Duxford is iirc that it was never a passenger plane. It was for testing and they put seats in back to show what it would of looked like with seats so museum goes could see it with seats.
x 8062
I've definitely seen the cap wedged but I've seen three Concordes in preservation and I can't remember which one it was!! :-D
x 1054
I'm pretty certain it's not the one at Duxford, I would of remembered that, like the first time you see a Fairey Gannett, unforgettable
x 8062
OK, then I'll plump for the Brooklands one and check it out next time I'm down there! :)
x 1054
The guys at Duxford used to play games with the planes, it was usually welly boots with a bit of overalls sticking out of a jet engine etc just to see confused museum goers faces. Maybe that's the type of thing you saw.
