Towbar hints
bikeryamaha
Towbar hints
Hi. I am the danish owner of a c3/2013 with a 1.2 petrol engine and manal 5 speed gearbox. VIN VF7**************[VIN obfuscated, can be read by forum staff]. I have just bought an original towbar - inclusive cable-loom, out of the local scrapyard. I have been searching for an official description on how to intall the goods. Until now only found a description of unorginal cabeling. My loom is stamped with the identification: '858246' and the box is labelled: BSC B03 00. I should be so happy if you support me on solid information. Best regards from Copenhagen.
- x 6948
Re: Towbar hints
Unfortunately, the info you have provided are specific to the components and not the actual electrical wiring kits - which are very specific to the vehicle they are being installed on.
There are only 2 official wiring kits, one harness for a 7 channel and another harness kit for 13 track. So I can't advise on what it is you have obtained as those are not official part numbers.
bikeryamaha
Re: Towbar hints
My set is with 13 pins. Bedst Regards Henrik
- x 6948
Re: Towbar hints
I don't know if this will help, but it's the guide for the specific 13 track harness for this vehicle, so may not be the same, but beware you will need a Lexia Diagnostic kit with Diagbox to code it.
Fitting Instructions for 13 Track Harness (Part 9428 G2)
bikeryamaha
Re: Towbar hints
Thanks a lot. I am sure this was absolutely what I dad hoped for. Exellent help, thanks
Henrik
Henrik
- x 6948
Re: Towbar hints
No problem, good luck.
bikeryamaha
Re: Towbar hints
Oh no - I ran out of luck. My part is for 7 pins.
