Hi, I have following errors
P0336
P0337
P0338
U1208
U1213
Driving on a highway engine is sometimes jerking and losing power for a split second.
Reading some posts here on forum, the problem could be with crankshaft sensor, so I need part number for speed/crankshaft sensor.
Thnaks!
X7 Power Loss
nomad123
- x 5
X7 Power Loss
Reason: Moved out of Parts Thread
- x 6958
Re: X7 Power Loss
Please only use the Parts thread for parts requests - I've moved your post into a new Topic.
There's a specific technical bulletin for codes P0336, P0337, P0338, P0339.
In the presence of one or more of the above, replace the Engine Speed Sensor (not the camshaft sensor). Then clear the fault codes.
In case you need the part info, I've put it here:
(4) Engine Speed Sensor, part: 1920GJ, £79.22
Rhothgar
- (Donor 2026)
- x 225
Re: X7 Power Loss
Hi nomad123nomad123 wrote: 26 Sep 2024, 17:17 VF7**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]
P0336
P0337
P0338
U1208
U1213
Thnaks!
As you have read forum posts in order to try and diagnose your fault, it would be really useful if you could update this post once you have fitted the replacement Engine Speed Sensor so that others may ascertain if this could likely resolve their problem in future.
Good luck with the replacement.
Thanks in advance
nomad123
- x 5
Re: X7 Power Loss
Thank you for replying!
As soon as I replace the sensor I will give feedback.
