On your Bike
moizeau
- x 423
Re: On your Bike
Valves in the exhaust ports that give it increased bottom end grunt. The bike was known as a 'Powervalve' or 'Valve' to us to distinguish it from the older LC (Elsie)
Pete
- x 8397
Re: On your Bike
Thanks Petemoizeau wrote: 15 Sep 2024, 13:55 Valves in the exhaust ports that give it increased bottom end grunt. The bike was known as a 'Powervalve' or 'Valve' to us to distinguish it from the older LC (Elsie)
moizeau
- x 423
Re: On your Bike
My Elsie was a complete one off.. Started life as a 250 then got 350 barrels and head but not off an LC, they are 2 separate cylinders, mine was off a TZ350 which was the race version, single piston ring and both cylinders as 1 unit. The carbs were 30mm Amals off a Norton rotary, eccentrically bored out (to keep the bottom of the venturi in the same place) to 34mm with tuned length cut down Fairy Liquid bottles (un filtered) as intakes. I did 0-118 in 11.8 seconds at The Bulldog Bash 1/4 mile 'run what you brung' in about 1990/1. It would live with almost anything in the day up to a ton, power wheelie in 3rd (no clutch required just a pull) and do a ton in 4th. Which is why, after owning a sedate Z250 prior, at 18 I fell off 3 times in the first month.
Pete
- x 3565
Re: On your Bike
I was probably there when you did thatmoizeau wrote: 15 Sep 2024, 16:19 I did 0-118 in 11.8 seconds at The Bulldog Bash 1/4 mile 'run what you brung' in about 1990/1.
- x 8397
moizeau
- x 423
Re: On your Bike
Forgot to mention, which was why I replied regarding reed valves, The 350 TZ doesn't have them. Reed valves are to give a stable tickover by getting rid of the spit back on road bikes, so mine had a TZ750 reed block and valves alu welded to the TZ350 barrels
Pete
moizeau
- x 423
- x 3565
Re: On your Bike
At the time I went with my mate on the back of his CB400(?) - I hadn't passed my test at that point
My first bike was an MTX125 which I used to trail ride with my mate - him on his power valved DT125..... which made it all but unusable on snowy lanes
After that was a mid-90s CB500, and after that my current ride - a 1999 V-F-R800 owned from new.
moizeau
- x 423
Re: On your Bike
VFR**************[VIN obfuscated, can be read by forum staff], injected version? Mate had 2 750's, bullet proof. Although I prefer Kwaks for their lines, older ones, Hondas are superb. Had a Blackbird, carb version, ballistic sofa and the build quality is was out of this world
Pete
moizeau
- x 423
Re: On your Bike
Hehe V f r 8 00 without spaces gets vinned
Pete
- x 3565
Re: On your Bike
The 800 is an Fi-x RC46 injected.... still under 30k miles
Pretty good condition
I had the choice of the V-F-R or Blackbird when I bought mine - they were both the same price, but I opted for the V-F-R. I also nearly got a Firestorm at the time as well - purely as I had one as a loaner whilst my bike was in for warranty work. I came back to the shop grinning from ear to ear
I was offered a V-F-R 750 from a mate - ultra low mileage and a pleasant dark metallic purple.... but how many motorbikes does one person need ? <don't answer that.... another mate of mine has over 30 of them
- x 7163
Re: On your Bike
This caught my eye but maybe not my most in focus camera work. Still not sure what make and model it is but it did have an L-plate on the back and it clearly says V125. Unfamiliar with the tank badge.
moizeau
- x 423
Re: On your Bike
https://www.mmcbikes.co.uk/post/keeway- ... ld-buy-461
Keeway V twin Cruiser?
Pete
moizeau
- x 423
Re: On your Bike
Firestorms bring grins. My mate with V FR750 pretended he wanted one from a local bike shop. 3 of us went out and ragged it. Burn outs, wheelies (all on private roads you know). Got back to the shop and he said it's not for him. 'We have another Demo here, a V FR800' Nah he said, demos get ragged
Pete
- x 7163
Re: On your Bike
The Keeway Group are a subsidiary of Zhejiang Qianjiang Motorcycle Group Co. Ltd. Since 1999, Qianjiang has marketed motorcycles outside China under the Keeway brand.moizeau wrote: 16 Sep 2024, 18:02 https://www.mmcbikes.co.uk/post/keeway- ... ld-buy-461
I think this is the model in my photo
Keeway RK V125C 2024![]() |
