Hi there
I got a fault code P0100 Quantity of air greater than the minimum threshold
I have changed the maf sensor but the problem still there any suggestions what can it be
Rabsus
Fault code p0100 Citroen c3 1.4 hdi
- x 6955
Re: Fault code p0100 Citroen c3 1.4 hdi
So your issue could also be related to the MAP sensor. If replacing sensors, make sure they are branded parts and not cheap ones as these can be faulty to start with.
Info on the fault for you:
| Fault Code: | P0100 |
| Description of Fault: |
| Conditions for Fault to clear: |
| Downgrade Modes whilst Fault is active: |
| Symptoms: |
| Suspect Areas: |
Rabsus
Ok I will try to change the map sensor.
Thank you very much Mark
Regards Rabsus
Regards Rabsus
Rabsus
Many thanks Marc actually it was the map sensor
- x 6955
Great, that was number 2 on the list of suspects, so pleased that's sorted. Thanks for taking the trouble to update the thread.
