Hello, colleagues. I am writing for advice on a problem on my 2012 DS5 2.0HDI
The car after acceleration, either slowly or quickly, goes into emergency mode and the engine light comes on and there is no power (it remains without turbo). The errors it records are P0299 and P2562.
As far as I have learned, they are related to insufficient pressure of the turbine.
Whether it's dirty geometry, a leaky vacuum, or a turbo valve is a problem.
It is interesting that it does not do it constantly, I delete the error and it is possible that the next 50 km will not be a problem.
Please give your opinion on the issue
Thank you
Citroen Ds5 2.0HDI PROBLEM
- x 6950
Re: Citroen Ds5 2.0HDI PROBLEM
I don't have your VIN (best to post it up for confirmation so correct engine system can be identified), but assuming it's a DW10CTED4:
| Fault Code: | P0299 |
| Description of Fault: |
| Conditions for Fault to clear: |
| Downgrade Modes whilst Fault is active: |
| Symptoms: |
| Suspect Areas: |
| Fault Code: | P2562 |
| Symptoms: |
| Suspect Areas: |
PontyAl
Hi guys, I had a similar problem with my 2.0 bhdi ds5 going into limp mode, apparently one of the reasons is there is a built in algorithm that forces limp mode if several DPF regen failures are detected between services, usually caused by short trips. I was advised to reset the service monitoring to zero, press and hold the test button under the instruments while starting until the counter runs down from 9 to zero, a simple procedure and solved my problem instantly.
Ds5fan
Hi, this is my VIN - VF7**************[VIN obfuscated, can be read by forum staff]
I tried this on autobahn- 3000k rpm about 15mins, but not successful .
It is interesting that while the engine was cold, it did not go into error.
Another thing is that the car has recently been with me and for about 400 km it has not errors codes . Since I changed the timing belt set oil and filters the problems started (I doubt it's because of this)
Ds5fan
Thanks for opinion. I drive it in autobahn several times . The DPF system seems ok . Behind the car there si have no smoke on low rpm or high rpm .PontyAl wrote: 08 Sep 2024, 16:16 Hi guys, I had a similar problem with my 2.0 bhdi ds5 going into limp mode, apparently one of the reasons is there is a built in algorithm that forces limp mode if several DPF regen failures are detected between services, usually caused by short trips. I was advised to reset the service monitoring to zero, press and hold the test button under the instruments while starting until the counter runs down from 9 to zero, a simple procedure and solved my problem instantly.
I resetting service interval a few times , but the problem is there.
