Rd45 callers name problem
This unit is the RD4 or RD45 system, made by Continental.
Usually standard equipment unless another system is specified as an option. There are Single & Dual Tuner versions. RD45 features over the RD4: The RD45 has USB connectivity & integrated Bluetooth module supporting Phone & Audio Streaming.
156er
Unread post by 156er »
Hi guys,
The factory rd45 radio does not show the callers name, when somebody calling me. After I press “yes”, on the display I can see the name of the caller, as it saved in my phonebook….
But I dont know before, I wanna answer or not.. :))
Originaly was a rd4 in the van. I swaped it to a rd45+screen type c.
Berilngo 2010 Van.
Thanks any help!!!
Zsolt
156er
Re: Rd45 callers name problem
@GiveMeABreak do you have any idea? Thanks a lot!!
156er
Hy.
Do you know guys, what can be the problem? It’s a bit annoying….
Thanks for your help!
x 1438
Unread post by xantia_v6 »
Maybe your phone does not allow the RD45 to read the phone book or get the caller ID?
It could be an incompatible phone.or maybe phone settings.
x 1911
Has the display ever worked in the manner that you want?
x 6953
Try removing the paired telephone (completely) from the RD45 and also delete the bluetooth connection from the phone.
When you re-pair them again, pay special attention to the phone privacy settings to allow the RD45 access to your contacts. If you don't do this, you won't get any contact information displayed. The issue is likely to be that your smartphone is much newer than the RD45, so has more privacy settings to check when connecting.
156er
Paul-R wrote: 08 Sep 2024, 09:09 Has the display ever worked in the manner that you want?
I dont know. I’ve bought it from ebay/uk. From a 2014 Berlingo, I think….
156er
GiveMeABreak wrote: 08 Sep 2024, 11:32 Try removing the paired telephone (completely) from the RD45 and also delete the bluetooth connection from the phone.
Done that before… many times. Still not working.
156er
xantia_v6 wrote: 08 Sep 2024, 07:58 Maybe your phone does not allow the RD45 to read the phone book or get the caller ID?
Thanks.
With Iphone 11pro and iphone 13mini either not working.
Strange, during the call, if somebody call me, it show the caller’s name!
156er
156er wrote: 08 Sep 2024, 13:57
Call list phone book works fine! Just that thing not.
robertel99
Unread post by robertel99 »
try disconnecting from bluetooth, remove all conections, remove + from battery leave it off a bit then reconnect and see. my phone was not connecting once and a battery disconnect worked.
156er
Hy,
In the Diagbox, on the list of the begining, “Multifunction display- unknow device”, why is that?!
The display works great, it seems the BSI can not recognize the display. The van is a 2010 model, the second hand display is 2014, could it be the problem?
Thanks for you help… it makes ne crazy😂🤦???
shtu
x 75
Unread post by shtu »
156er wrote: 29 Sep 2024, 10:12 In the Diagbox, on the list of the begining, “Multifunction display- unknow device”, why is that?!
Because the van is old enough that it shouldn't have that type C display so diagbox doesn't recognise it properly - elsewhere you'll still see mentions of RD4 (eg in the BSI config)
When you access it in diagnostics, you will be given the chance to choose which type it is. Pick Type C Dot Matrix.
This probably has no bearing on your actual problem though, and I too suspect your phone is the root cause.
156er
Thank you for your answer.
Yes, it is only rd4, I can’t see rd45 nowhere.
There is 3-4 diferent options for the display, I can chose “Type_C?”, but nothing changes.
I can’t see any options in the phone, so have no idea what else can I modify.
Thank you!!🙂
156er
Is there any option, to update the BSI?
At the local Citroen dealer maybe?
