DS 5 Engine repair needed, no fault code
babulasi
Hi, I have a problem with my DS 5 2.0 blueHDI...so yesterday I go from work and sudenly a warning come up with message ENGINE REPAIR NEEDED, the car is running as normal, no lose of power, no check emgine light...I check with Torque PRO for faults and did t show any...what the heck is going on?!
- x 6955
Re: DS 5 Engine repair needed, no fault code
Very likely some emissions related issue, but it really needs Diagbox to check for any faults as not all after-market scanners can read everything.
Is this a Hybrid model?
babulasi
No, it is 2.0 hdi 180hp, automatic gearbox...it happen after I stop, start/stop system was on and after I released the pedal from brake, engine start and the message pop in
- x 6955
Ok, so I have heard that the alternator belt can be a cause for this - and as you mentioned it came up about the time of the engine re-start, it may be worth investigating here...
babulasi
you think the belt has stretched and is slipping? I'll check it out anyway, thank you so much for the useful information
- x 6955
It's just a possibility, but without a fault diagnosis, it's hard to say. I just mentioned this as it has been known with Stop Start systems and this message when restarting.
babulasi
I understand... I'll check the belt, and if everything is fine there, the next thing is the battery... Of course, I'll also run a diagnostic check at the service center along the way
OnlinePaul-R
- x 1929
Is this a reversible alternator system?
babulasi
I think it is...I check voltage while running, it is 14v, so that's not the problem... :/
OnlinePaul-R
- x 1929
No but the belt and accompanying pulleys, etc need to be in top condition.
heiluri
Hello,
I had this too on my DS5 2016. Engine Repair Needed message but the check engine light turned off. Hooked it to Diagbox and found the code P0494 62 Fan Assembly. Status Permanent - Lack of coherence between the status detected and the reference value of the slow speed.
Waiting for the spare part to arrive.
Alnum
Hey. That’s exactly what happens to my c4. Any chance you received the spare part and had it fitted? What spare part was it if I may ask? Thanks in advance!
- x 1438
You need to get the engine faults read with Diagbox or a professional quality diagnostic machine, otherwise there are too many possible faults to consider.Alnum wrote: 03 Mar 2025, 19:59 Hey. That’s exactly what happens to my c4. Any chance you received the spare part and had it fitted? What spare part was it if I may ask? Thanks in advance!
Alnum
It’s the same error code P0494 62.
- x 6955
| Fault Code: | P0494 62 |
| Description of Fault: |
| Conditions for Fault to clear: |
| Downgrade Modes whilst Fault is active: |
| Symptoms: |
| Suspect Areas: |
