Citroen dispatch 2,0 hi 2020 clear tube pipe hanging under engine
Leedscity
Unread post by Leedscity »
Hi there is clear pipe hanging under engine is this normal as I jack the car up I could see anywhere to attach it it does look like coming from under fuel filter one photo from underneath and one from top
x 5674
Re: Citroen dispatch 2,0 hi 2020 clear tube pipe hanging under engine
The bottom photo isn't working.
PaulC5
x 698
Unread post by PaulC5 »
If it comes from the bottom of the diesel fuel filter with the lower end hanging free, it is likely to be for when you drain the filter at a service to remove any water. Our C5 has one but I keep it in the garage rather than leave it on the car.
Leedscity
So nothing to worry about
