Xantia 1.9TD....wake up and back on the road after 10 Years
- x 8116
Re: Xantia 1.9TD....wake up and back on the road after 10 Years
Some people are just too fussy!!
Rhothgar
- (Donor 2026)
- x 221
We need to tie up a date for me to come down!CitroJim wrote: 15 Aug 2024, 06:22Be happy to have a look on my next visit Alasdair... As long as the transformer is good I should be able to make it live again...Stickyfinger wrote: 14 Aug 2024, 18:30 The rusty old battery charger does not work however.........Jim, you have a project to test/fix or throw out![]()
- x 2004
with Jim ?..he normally just lets me know when he is coming down
..... but since he has metamorphised into Laurence Llewelyn-Bowen I think he is busy making "Art" to populate his "space" so better to channel its "energy" through the medium of colour, texture and a non-binary sensual philosophy.............with an added AX or two
- x 8391
Stickyfinger wrote: 27 Aug 2024, 15:03 with Jim ?..he normally just lets me know when he is coming down..... but since he has metamorphised into Laurence Llewelyn-Bowen I think he is busy making "Art" to populate his "space" so better to channel its "energy" through the medium of colour, texture and a non-binary sensual philosophy.............with an added AX or two
It tends to be at quite short notice Roger, mainly due to my prevailing health. I rarely plan anything very far in the future as my ability to actually go ahead with plans is a bit of a lottery.
That said, if you want to try to arrange a potential date and can do at short notice we can try. I may have an opportunity early next month...
Rhothgar
- (Donor 2026)
- x 221
Yes Jim. Let me know a day or so before going or further ahead if possible and just keep me updated. I can then try and get down at same time whether it’s the e next time or the time after.
Otherwise it will be next year or perhaps 2026 at this rate…
- x 8391
Will do RogerRhothgar wrote: 27 Aug 2024, 18:43 Yes Jim. Let me know a day or so before going or further ahead if possible and just keep me updated. I can then try and get down at same time whether it’s the e next time or the time after.
- x 2004
Be ready to WORK slaves !...see you both Tuesday
Attacking the very very loud front-RH wheel bearing............hub carrier off, cleaned and primed ready for a new bearing to be pressed in (when it arrives).
- x 8391
Great work Alasdair
I'll be all good to go straight to work when I rock up on Tuesday morning
- x 5674
You will need a cup of tea first though!
- x 2004
Coffee for them both, Double Turkish with an extra shot....and a can of RedBull as a chaser....
- x 8116
You'll be scraping Jim off the ceiling then Alasdair, a snow shovel should work well!!
- x 8391
mickthemaverick wrote: 31 Aug 2024, 05:14 You'll be scraping Jim off the ceiling then Alasdair, a snow shovel should work well!!![]()
Looking forward to seeing you on Tuesday
I have my in-line pressure tester and balljoint tool packed ready, along with my overalls and arm protectors
Rhothgar
- (Donor 2026)
- x 221
Sorry Alasdair. Unfortunately I will not be able to make this Tuesday as I have a prior engagement at 6:30 in the evening and I think it will be too early a start and then I'll need to be box-fresh at 6:30pm which wouldn't happen with such an early start.Stickyfinger wrote: 30 Aug 2024, 18:10 Be ready to WORK slaves !...see you both Tuesday
I've said to Jim that it will likely be the next time all being well. I have to get a new cylinder too to come down with.
- x 2004
OK mate....BTW, did you ever fit those Strut tops I gave Jim for you ?
- x 2004
Well.....that is an "interesting" discovery !....bugger, but not really a surprise on a 30 year old Xantia.
Note the corrosion "waisting" on the strut body caused by a split gaiter and the subsecant build-up of crap inside.
I also have to remove the steering rack to replace the gaiters on that as they all need doing.
I think it will be quicker to remove it whole rather than my normal "struggle" method.
The car being so simple...vrs the v.6 Activa.... will help a LOT and make it a somewhat easier job to do as access is so much better (or not impossible without removing the engine
