Hello! Can you please help me find the pinout of the electrical connector and implicitly of the relay, thank you very much!
Peugeot 308 coolant fan relay pinout
- x 6956
Re: Peugeot 308 coolant fan relay pinout
With the exception of the wiring codes, most of the component codes are indexed here:
PSA Electrical Diagrams - Wiring & Symbols Codes Index
The Fan control is at 1522.
Wiring
There is a 2 pin Grey and 4 pin Black connector
The 2 Pin 1514 wire is the fan control and the BM01 goes to the engine fuse box (Maxi Fuse MF03)
4 Pin Connector
1590A: Fan unit relay power supply
1550Z: fan control 2 (-)
1599Z: Fan unit diagnostic info
1540Z: fan control 1 (-)
