Hello.
The following three error codes came up.
Black smoke comes from the exhaust even at low loads. At higher throttle, a large cloud of smoke is emitted.
At 1800-200 rpm, with steady throttle, there is a fluctuating, throbbing rpm. There's no such thing above or below.
The error codes:
P0100
P3008
P1351
The subject is a 2009 B9 Berlingo van. 9HX engine code.
Does anyone have any idea what might be causing this?
Thank you.
Fault codes
- x 6945
Re: Fault codes
We'll need the VIN to relate the faults to the correct EMS. Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
156er
Re: Fault codes
- x 6945
Re: Fault codes
Ignore the P1351 - that's a common fault related to glow plugs / relay.
Your issue is likely to with the Mass Air Flow Meter.
| Fault Code: | P0100 |
| Description of Fault: | Flowmeter signal: Air flow not plausible. Negative difference of 200 to 300 mg/stroke between the measured air flow and the air flow reference value for 2 (for an engine speed higher than 1500 rpm). |
| Conditions for Fault to clear: |
| Downgrade Modes whilst Fault is active: |
| Symptoms: |
| Suspect Areas: |
| Fault Code: | P3008 |
| Description of Fault: | Flowmeter signal: Air flow too strong. Negative gap for 8 seconds between the theoretical air flow and the measured air flow as calculated by the ECU: The measured air flow is greater than the theoretical air flow by 71% to 76%. Conditions of activation of the diagnostics:
| Symptoms: |
| Suspect Areas: |
156er
Re: Fault codes
Thanks. I cleaned the MAF sensor. It was quite dirty. Since then, there is no twitching at low revs.
Also, I don't see it smoking heavily.
- x 6945
Re: Fault codes
Great - just be very careful as the MAF wire is very sensitive and should be cleaned with special MAF cleaner. Never touch the wire.
Thanks for the update.
156er
Re: Fault codes
It was a special maf cleaner.
Thanks for your help.
