Torx Bit
- x 8378
spider
- x 77
Re: Torx Bit
It may be worth you purchasing a *good* quality set of these as they are so handy its difficult to imagine a modern toolbox without them. If funds are tight (well, everyone's are at the moment lets be honest) Halfords may offer some at a reasonable price, the 'pro' stuff, although I've not looked.
Sometimes there are good quality ones on Ebay (yes really) as I've replaced a couple of my Mac ones with ones from there, smaller sizes and they have been good but I tend to steer clear of the really cheap stuff as its no good if it chews things up...
Torx bolts especially as they are annoying to get out if someone's damaged them, sods law says it happens to the inaccessible ones, XUDT inlet manifold in my case, the one nearest the OS the "difficult at the best of times" one (I think it was a rounded out hex key but same principle)
Andy.
- x 8378
Re: Torx Bit
Absolutely Andy. You can't really do much on a PSA vehicle without them really...spider wrote:It may be worth you purchasing a *good* quality set of these as they are so handy its difficult to imagine a modern toolbox without them.
Quality is an issue though. Those caliper bolts will be tight and they need a good bit. Some are too soft and twist under heavy use and others are too hard and shatter with a breaker bar on them...
Draper ones I find are made of cheese but the Halfrauds Professional ones I find are excellent. I've given the latter some very severe abuses and even a T27 one will live to tell the tale after being on the end of a three foot breaker bar...
A tip for the caliper bolts... The heads are a bit shallow and tend to collect dirt which prevents the bit fully bottoming in the head. Clean them out and then hammer the bit in to make sure it's fully bottomed. Then use a long breaker bar gently rather than a short one harshly...
The bolts - if they've not been out previously - will be Loctited. A tad of heat on the bolts will help soften it. Be careful though as there's plenty to damage nearby if the flame is too big. Ideally heat with oxyacetylene...
guzgog
Re: Torx Bit
Cheers everone for all your useful info
Chlorate
Re: Torx Bit
It's worth getting a nice selection of 6 and 12 point torx bits. When they get old and crusty the socket in the bolt is quite easy to round out, and when that happens a nice solution is to select a slightly larger 12 point bit and hammer it in.
Alex
Alex
Citroen Xantia Exclusive HDi
previously:
Citroen ZX Volcane - RIP
Peugeot 106 XN... stolen and destroyed by Kent Police
previously:
Rhothgar
- (Donor 2026)
- x 221
Re: Torx Bit
Good advice never dies!
Just searching the internet in general for advice on a sturdy enough Torx bit for brake carrier bolts and here I am...
I think I actually sheared one of my Halfords Professional ones. Need to get it swapped out!
I get another one when I am down there. They are T45 on the Peugeot 3008 if anyone reads this in future. Not much meat in them to prevent them from shearing.
Geodore look a nice brand though but they should be at £55 for Torx bit...
- x 5673
Re: Torx Bit
Würth tools have an excellent reputation but are quite expensive.
Rhothgar
- (Donor 2026)
- x 221
Re: Torx Bit
Thanks Steve. Sylvia is paying...myglaren wrote: 14 Aug 2024, 17:46 Würth tools have an excellent reputation but are quite expensive.
- x 1458
Re: Torx Bit
Not a direct answer, but I bought a Torx bit that was packaged as being suitable for cylinder head bolts. It seems plenty strong enough.
Rhothgar
- (Donor 2026)
- x 221
Re: Torx Bit
Good idea. I’d doubt though that any vehicle has T45 head bolts. They tend to be T60 maybe T70?xantia_v6 wrote: 14 Aug 2024, 18:06 Not a direct answer, but I bought a Torx bit that was packaged as being suitable for cylinder head bolts. It seems plenty strong enough.
But you’d imagine the impact driver ones would be strong enough though Jim seems to indicate otherwise.
