Hi, does anyone know what the light sensor on the dashboard is for?
It's that little ball behind the speedometer chapel.
I was doing an automatic headlight calibration via diagnostics yesterday and the live readings of the light conditions are taken from the cluster sensor by the mirror (with rain sensor).
I could not find the readings given by the small sensor behing speedo anywhere.
Sun sensor
Arkis
- x 27
Sun sensor
Citroen C4 Picasso 2013, 1.6 e-HDI 85kW, 6 speed manual
Peugeot 206, 2005, 1.4i 8v, 55kW, 4 speed AT
Peugeot 208, 2019, 1.2i PureTech, 61kW, 5 speed manual
Opel Insignia, 2015, 2.0 CDTi, 120 kW, 6 speed AT
Hyundai Santa FE 4WD, 2015, 2.2 CRDi 145 kW, 6 speed AT
- x 1493
Re: Sun sensor
I believe it's supposed to detect if the sun is shining strongly, and it turns up (down?) the A/C to make it colder to counteract the sun shining in.
Arkis
- x 27
Re: Sun sensor
That makes sense. Thank you.
- x 6946
Re: Sun sensor
Yes, it detects the angle and intensity of the sun hitting it for use in climate control systems.
- x 5674
Re: Sun sensor
Answered a question for me too as I have such a lump on the dash of my Mazda and often wondered as to its function. Kept meaning to cover it over and see what happened, except the doors would probably fall off.
- x 6946
Re: Sun sensor
Ha! I'm sure I have a 50 page article on its operation somewhere.....
