x 2354
Unread post by MattBLancs »
Good morning,
Blue 308 SW, VF3**************[VIN obfuscated, can be read by forum staff]
Could you confirm:
Hub nut torque value? Normally 325 Nm but was mentioned about "self locking nuts" so wondering if significantly different.
Gearbox oil volume? Realised during driveshaft swap I'll be changing that, hence figure needed . Nice big tub of 75w80 ready to go. Guess it's not got a level plug so drain and add a measured amount?
Cabin filter part number and location too please
Thanks a lot! :)
x 6945
Matt - some confusion...
This 308 with the VIN ending 941 above is not showing a Hub Nut, as the rear hub assembly is not built into the rear disc, unlike the other 308 - have you got the correct VIN? If correct vehicle, can you tell me what other hub nut you're referring to before I answer the other questions so we're talking about the same vehicle, thanks.
cs101
x 6
Unread post by cs101 »
Thanks, Marc
x 2354
GiveMeABreak wrote: 03 Aug 2024, 11:25 Matt - some confusion...
Sorry Marc, front driveshaft nut rather than rear wheel hub nut - mixing up my terminology! It's the one you dug out the part number for me recently =
Item 10 here: viewtopic.php?p=807117&hilit=Driveshaft#p807117
x 6945
No worries
(10) Driveshaft Self-Locking Nut, Torque: 28,5 da.Nm
As for Gearbox oil, you're supposed to replace the amount removed, but if unsure, drain and refill. Quantities here depending on operation:
Quantity of oil to fill after draining: 2,1 ± 0,1 litres.
Quantity of oil to fill after an overhaul: 2,2 ± 0,1 litres.
Oil quality: 75W80.
Cabin Filter:
(7) Cabin Filter, 3 Options:
OEM Original Carbon Filter (Particles & Gas), part: 9804163480, £50.96
Cheaper Carbon Filter (Particles & Gas), part: 1612920480, £21.07
Anti Allergenic (High Performance Carbon, part: 1616959280, £63.65
On a LHD this on on the right side, so can't see it being different for a RHD. I believe you need to remove driver side centre console trim (remove centre console side trim cap to reveal screw). You'll need to find the cover as below and remove this to extract and refit the 2 filters. There are 2 plastic clips (tabs) to release the cover.
x 2354
Absolutely spot on, thank you!
trollkarlen
x 4
Unread post by trollkarlen »
Can i get the oe nr for the front dash multifunction camera for lane assist.
Thanx alot
x 6945
(5) New OEM Multifunction Video Camera, part: 1679619080, £620.42
Exchange Multifunction Video Camera, part: 1692666580, £456.48
Remember, in addition to the camera, on this vehicle you also have ARTIV (Distance Control Radar) installed into the front grille. Sme vehicles have camera only based system, others use both camera and ARTIV unit, so you have both.
Huskyxantia
x 917
Unread post by Huskyxantia »
VF3**************[VIN obfuscated, can be read by forum staff] my vin ,This could be a minefield of an ask , need a 10mm bolt for the abs sensor possible part numner , thanks Marc.
:-D
x 6945
(70) MUL TH Screw with Washer, part: 692297, £2.38
Huskyxantia
x 917
Cheers marc all sorted now 👍
:-D
trollkarlen
x 4
Thanx alot!
You dont have access to the repair instructions also so i can get some input in how to remove the inner roof/dash mirror console?
trollkarlen
x 4
Can i please also get the oem number for the rear license plate light, both left and right if they are different ?
x 6945
(2) Number Plate Lamp, part: 9815226680, £20.36
(10) Bulb, part: 6216A1, £2.16
x 6945
trollkarlen wrote: 04 Aug 2024, 22:47 Thanx alot!
Sorry, no.
