Sounds like one of the guys I used to play pool with. You used to be able to tell when he'd just started a game from the percussive crack that was audible even from well outside the pub!Hell Razor5543 wrote: 24 Jul 2024, 11:46
Erm, no I don't! (that is my nickname when I play pool, because when I break off the pack explodes!).
Zelandeth
- x 1586
Re: Simon's new Xantia V6 and Leaf blog
Current fleet:
Michel
That is a shame, as sadly, my budget doesn't yet stretch to trailering. I hope it goes to a decent home!Mandrake wrote: 23 Jul 2024, 19:25 Thanks for showing an interest but unless you're willing to trailer it and do battle with the brake hoses and brake lines it may not be the project you're looking for.
- x 1978
Simon....would you takes some stuff of it before you scrap it ? (if you do)
There are some bits I could do with.
DHallworth
- x 163
Just been reading your thread about the brakes, Simon.
On the XM, under the scuttle panel on the drivers side is a brake doseur valve which when seized causes the front brakes to bind. I had it before on one of my XM's. After giving it a good going over with some Plusgas and working it back and forth it freed off nicely and never gave me any problems again.
I'm just thinking that it would be unusual for you to have 2 collapsed brake pipes causing problems at the same time so am wondering if the Xantia could have the same valve.
David.
David.
'98 Xantia Activa V6
'00 XM V6 Exclusive
'09 C5 2.7 HDi Exclusive
‘10 C5 3.0 HDi Exclusive
'12 C6 3.0 HDi Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
- x 1387
The Xantia does not have the same doseur linkage as the RHD XM. The pedal pushes more or less directly on the doseur, as it does on a LHD XM.
- x 694
Hi,Stickyfinger wrote: 26 Jul 2024, 09:30 Simon....would you takes some stuff of it before you scrap it ? (if you do)
I'm not really interested in breaking the car on my driveway I'm afraid unless it's something very trivial that doesn't prevent the car from being moved/driven.
I sometimes need to park the car out on the road to make room for other things, as soon as the MOT / tax etc runs out (or if I SORN it) I won't be able to do that and it will be stuck on my driveway until it's gone. It's not possible to get a truck through my gate to pick up a non-driving car (the gate is barely wider than the wing mirrors and the driveway doesn't align with the gate) so I can't disable it and to be honest stripping the car on my driveway would see me permanently in the doghouse!
- x 694
Hi David,DHallworth wrote: 29 Jul 2024, 13:49 Just been reading your thread about the brakes, Simon.
David.
While the doseur could theoretically cause an issue with binding, as xantia_v6 notes there's no linkage on a RHD Xantia the brake pedal pushes directly on the doseur valve.
Also it wasn't doing this until after I had everything apart to fit new discs (and I have since removed and refitted one caliper a second time and checked everything is mechanically free) so it would be strange for the doseur valve to suddenly have an issue, but much more reasonable that 27 year old original brake hoses could not stand up to the flexing the experienced while the caliper was removed and collapsed.
- x 7162
Just read your very comprehensive advert here Simon, and its most generously priced to sell, so best wishes for moving it on.
- x 1978
I understand....however I was after a few bits that would not stop it driving (but would sink the suspension)....so , if by chance (it would be sad) the car does have to be tracked away for scrap please remember this before it goes.Mandrake wrote: 29 Jul 2024, 19:59Hi,Stickyfinger wrote: 26 Jul 2024, 09:30 Simon....would you takes some stuff of it before you scrap it ? (if you do)
I sometimes need to park the car out on the road to make room for other things, as soon as the MOT / tax etc runs out (or if I SORN it) I won't be able to do that and it will be stuck on my driveway until it's gone. It's not possible to get a truck through my gate to pick up a non-driving car (the gate is barely wider than the wing mirrors and the driveway doesn't align with the gate) so I can't disable it and to be honest stripping the car on my driveway would see me permanently in the doghouse!![]()
Sadly, being down south there is no chance of me taking it whole.
Michel
It would be a terrible shame if someone came to collect it, drove it a few miles then found the brakes had a fault and had to use their nationwide recovery service to get home.
- x 1978
It would.... but I would have to be there do do that and with looking after Mum I cannot arrange that (otherwise I would)
- x 694
I don't want to jinx it but I may have some news regarding the seizing brakes tomorrow thanks to the services of a small blow torch and a pair of mole grips...
- x 8167
Excellent!Mandrake wrote: 31 Jul 2024, 21:34 I don't want to jinx it but I may have some news regarding the seizing brakes tomorrow thanks to the services of a small blow torch and a pair of mole grips...![]()
Michel
If you manage this I shall still have it, and I'll pay you for the hoses and discs on top..Mandrake wrote: 31 Jul 2024, 21:34 I don't want to jinx it but I may have some news regarding the seizing brakes tomorrow thanks to the services of a small blow torch and a pair of mole grips...![]()
- x 8167
That's got to be a resultMichel wrote: 01 Aug 2024, 09:50If you manage this I shall still have it, and I'll pay you for the hoses and discs on top..Mandrake wrote: 31 Jul 2024, 21:34 I don't want to jinx it but I may have some news regarding the seizing brakes tomorrow thanks to the services of a small blow torch and a pair of mole grips...![]()
