Edited in: For completeness it seems the plug would have fed the 5 disc CD changer Details here
- x 8107
Ok thanks again Marc, first class service as usual, found one on the bay for £18 so that will do fine
MixerFistit
- x 14
207 CC 1.6 HDi
Hi, I'm servicing the above to bring it back to good health after neglect from previous owner.
They had a k&n style filter jammed onto the back of the MAF at the back of the engine sucking in some nice warm air
the old box was in the boot but it seems to be missing some sort of insert where the 3 bolts meet the MAF. There doesn't seem to be any good seal between the 2 parts and inside the Airbox, the oval shape is asymmetric inside. Before I go out and get a completely new airbox is there a separate part for this missing piece?
Also, am I right in thinking the Total Energies Ineo First C2 0W-30 oil is still the best option for these older DPF vehicles?
Many thanks
Many thanks
307 CC 2.0 HDI
Sold/dead
Mk1 Dispatch 06 Face lift - 2.0 HDI - RHZ (sold)
2x xsara picasso 1.6 HDi
2x mk1 C4 Pic and a mk1 C4 GP
1x mk2 C4 Pic
C8 2.2.hdi (6 seat Exc) van/can
207cc 1.6 hdi (project)
Sold/dead
1x mk2 C4 Pic
- x 6957
Here are t he diagrams for the air filter and secondly for the MAF: If you can see the specific part on any of them let me know Diagram 'A' or 'B' and the item numbers.
As for the specific oils as per the VIN:
Look at the latest Oil specification in the guide I have updated yesterday. Refer to the engine code (DV6TED4 with Particle Filter) under the Country 'A', 'DV' engine table:
Stellantis Recommended Engine Oils Updated 12th July 2024
| Diag A Air Filter | Diag B MAF |
MixerFistit
- x 14
Thanks Marc, it's probably just the seal (13) in Diag B although I still need to get (6) and (9) Diag A, I can see those on ebay so just the seal 13 B.
But I'm also wondering whether it's possible to forget the original design and have something similar to the fiesta with the airbox at the front. Probably a faff extending the MAF wiring though.
307 CC 2.0 HDI
Sold/dead
1x mk2 C4 Pic
Sold/dead
1x mk2 C4 Pic
Steve Walsh
- x 516
Evening all
Need to put a full set of discs and pads on a mates 508 but our local independant parts supplier says there is different diameters and wants them removing and measuring first, bit of a pain, I would like to do the job in 1 go
Vin, VF3**************[VIN obfuscated, can be read by forum staff]
Is it possible to find out or if not the OE part numbers for the discs
Thanx
Thanx
- x 6957
BMixerFistit wrote: 26 Jul 2024, 15:33 Thanks Marc, it's probably just the seal (13) in Diag B although I still need to get (6) and (9) Diag A, I can see those on ebay so just the seal 13 B.
(13) Flowmeter Seal, part: 1920NJ, £8.81
A
(6) Air Intake Pipe, part: 143472, (NFP)
(9) Air Hose, part: 1434C1, £85.94
- x 6957
Before I put up the parts, this VIN is for a 308, not a 508 - Can you please clarify Steve.Steve Walsh wrote: 26 Jul 2024, 17:40 Evening all
Thanx
Steve Walsh
- x 516
Sorry marc. 308 GT Line, Souldnt do this when wine is involved
- x 6957
Here Steve:
Front Disks
(1) OEM Genuine Front Disks, (DIAM 304 EP 28), part: 4249K1, £156.85
Cheaper PSA alternative, part: 1687772080, apart: 1687772080, £78.42
Rear Disks
(1) OEM Genuine Rear Disks (DIAM 268 EP 12), part: 1609582880, £163.60
Cheaper PSA alternative rear disks, part: 1687772580, £91.76
Front Disks
Rear Disks
Steve Walsh
- x 516
That's great Marc
Thanx, have a good weekend
Timmycitroen
Hi after a part number for c4 grand Picasso 2015 cam sensor
Vin VF7**************[VIN obfuscated, can be read by forum staff] 3AAHRM FJ658196
Thanks in advance!
Thanks in advance!
Huskyxantia
- x 906
Hi marc, ive just hit a blind pot hole and its smashed the ns front whel bearing so im needing Steering Knuckle & Hub Bearing front left , (ns) Peugeot 308cc part numbers Vin VF3**************[VIN obfuscated, can be read by forum staff] thanks .
Husky.
- x 6957
Several Options:
(1) (Includes 'A' & 'B'), Front stub Axle Carrier (Left) part: 364696, £512.20
(3) Front Wheel Hub, part: 330785, £189.77
(4) Front Hub Bearing Assembly
OEM Original, part: 1606623580, £145.61
PSA Cheaper, part: 1681935280, £32.16
(6) Steering Rod Ball Joint Kit (Left):
OEM Original, part: 381789, £121.75
PSA Cheaper version, part: 1610936880, £65.93
- x 2341
Good morning,
A few questions, no rush:
Grey 308 SW, VF3**************[VIN obfuscated, can be read by forum staff]
Rear trailing arm/beam - there is a bush front end of the beam, can you confirm number (and price likely for amusement value) of this bush? (I think it is 5134G4, Autodoc lists two: one with a 12 mm central hole, the other 16mm - so any dimension data listed is also useful.
Can you confirm if there should be an exhaust heat shield down centre of the car? (There is under fuel tank and another under rear silencer - but the main long straight length, hotter as nearer the engine: nothing at present! Seems odd)
Second, for the Blue 308 SW, VF3**************[VIN obfuscated, can be read by forum staff]
Could I have a diagram for the aerial - not sure if GPS and radio (DAB) are both the roof mounted aerial?
Could you confirm if a towbar kit is listed for this car? Lots of aftermarket kits seem to state "excludes GT" so am interested if Peugeot also excluded this trim.
Thanks as always
Thanks as always
GORAX
- x 14
Hi,
Where exactly is the cabin filter located? I want to change him.
GOOGLE TRANSLATE
