- x 6956
On the C1 the VIN is usually located on the crossmember under the front right seat.
dave101ua
Thank you, Marc !GiveMeABreak wrote: 24 Jul 2024, 20:11It's Marcdave101ua wrote: 24 Jul 2024, 17:42Hello Mark!
Could you please tell me part number for the chain which is shown on picture ( Number 3) and also when it should be replaced ?![]()
(3) Camshaft Timing Chain, part: 0816F6, £78.30
- x 2337
Good morning again!
Peugeot 308 SW 2.0 HDI
Vin VF3**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]
Could you confirm part numbers for the following please:
The driveshaft nuts pricing please? I can't seem to locate them searching online with the number kindly given here:
viewtopic.php?p=806492#p806492
Also, can you confirm number for the front brake caliper guide pin cover/caps?
Noticed I've caps on one caliper and exposed Allen bolt heads on the other!
Could I have the "build spec sheet" as per Mick's info given:
viewtopic.php?p=806408#p806408
- if better not clogging up this fine thread, you can put in my blog post instead:
viewtopic.php?t=73821
Thank you!
Thank you!
- x 8087
Morning and not urgent. Could you please tell me what is missing in the bottom of my central armrest on the C4 VTR+. When you lift the lid and look down there is no floor but there is the end of a cable with a blue 12 pin connector laying loose in the bottom. Curious to know what is missing and the part number for it? Thanks
- x 6956
Assume this is for your 308:MattBLancs wrote: 25 Jul 2024, 07:31 Good morning again!
Thank you!![]()
(10) Self-Locking Nut, part: 9813722580, £17.90
(78) Self-Locking Nut, part: 693584, £0.42p
(11) Set Column Screw, part: 443914, £34.78
I'll put your spec. sheet in your blog Matt.
tearing hair out
- x 19
Hello Marc. This might be a bit of a needle-in-a-haystack - not sure. I have a leaking cooling system manifold(?), on the back of the engine near the cambelt, but it doesn't look like any of the cooling system parts in the RTA manual (to me anyway). Two outlets on top, but one is blanked off. One on the left.
2.2HDI C8 - can you see the VIN in this post still? Otherwise I'll go and find the V5. viewtopic.php?p=759416#p759416
I suspect it's NFP and I might have to find a second hand one - bonus points if you can tell me if the same part was used on the 2.0HDI, please?
Thank you very much, Paul
Paul
I would have more Citroens if I had the space...
- x 6956
There are 2 diagrams for the centre console. Let me know 'A' or 'B' and the item number Mick.mickthemaverick wrote: 25 Jul 2024, 07:36 Morning and not urgent. Could you please tell me what is missing in the bottom of my central armrest on the C4 VTR+. When you lift the lid and look down there is no floor but there is the end of a cable with a blue 12 pin connector laying loose in the bottom. Curious to know what is missing and the part number for it? Thanks![]()
| A Front Console | B Rear Console |
- x 1485
Paul
Yes, can still see VIN. You are right it is NFP:
It is also used on the 2.0 engine in the C8, Synergie and Dispatch 1 and 2
- x 8087
Hi Marc, It is the main box lining in diagram B, item 5 and possibly the insert item 6. Here is what it looks like:
nomad123
- x 5
Hello!
I need part number for engine Valve tappets and Timing chain tensioner kit ( maybe this part number 0849.23? )
Thanks!
Hello!
Thanks!
tearing hair out
- x 19
Thank you very much Richard.
Paul
- x 1485
Timing chain kit is 0849.23 (£243.70 in UK):nomad123 wrote: 25 Jul 2024, 13:50
Hello!
Thanks!
Tappets are 094288 (£31.50 each in UK)
- x 6956
Ok, so you don't have item (6), so that leaves (5) which is the STORAGE COMPARTMENTmickthemaverick wrote: 25 Jul 2024, 13:08 Hi Marc, It is the main box lining in diagram B, item 5 and possibly the insert item 6. Here is what it looks like:
FXT- - BLACK CORNELIE, part: 7589N9, £64.82.
Not sure what the 12 pin connection is for - it is on the central wiring though:
Have a look in your handbook to see if there's anything there that it could belong to.
The only thing I can think of is it may be for a 'connecting box' that has a Jack and USB port.
- x 8087
Thanks Marc, when you say I don't have item 6, do you mean it's missing in my photos or it wasn't fitted to my car?
- x 6956
Not fitted to your specific vehicle.
