x 6945
On the C1 the VIN is usually located on the crossmember under the front right seat.
dave101ua
Unread post by dave101ua »
GiveMeABreak wrote: 24 Jul 2024, 20:11
dave101ua wrote: 24 Jul 2024, 17:42
GiveMeABreak wrote: 05 Jul 2024, 19:01 Image
Hello Mark!
Could you please tell me part number for the chain which is shown on picture ( Number 3) and also when it should be replaced ?
It's Marc :-D
(3) Camshaft Timing Chain, part: 0816F6, £78.30
Thank you, Marc !
x 2341
Unread post by MattBLancs »
Good morning again! :)
Peugeot 308 SW 2.0 HDI
Vin VF3**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]
Could you confirm part numbers for the following please:
The driveshaft nuts pricing please? I can't seem to locate them searching online with the number kindly given here:
viewtopic.php?p=806492#p806492
Also, can you confirm number for the front brake caliper guide pin cover/caps?
Noticed I've caps on one caliper and exposed Allen bolt heads on the other!
Could I have the "build spec sheet" as per Mick's info given:
viewtopic.php?p=806408#p806408
- if better not clogging up this fine thread, you can put in my blog post instead:
viewtopic.php?t=73821
Thank you! :)
x 8123
Morning and not urgent. Could you please tell me what is missing in the bottom of my central armrest on the C4 VTR+. When you lift the lid and look down there is no floor but there is the end of a cable with a blue 12 pin connector laying loose in the bottom. Curious to know what is missing and the part number for it? Thanks :)
x 6945
MattBLancs wrote: 25 Jul 2024, 07:31 Good morning again! :)
Thank you! :)
Assume this is for your 308:
(10) Self-Locking Nut, part: 9813722580, £17.90
(78) Self-Locking Nut, part: 693584, £0.42p
(11) Set Column Screw, part: 443914, £34.78
I'll put your spec. sheet in your blog Matt.
tearing hair out
x 19
Unread post by tearing hair out »
Hello Marc. This might be a bit of a needle-in-a-haystack - not sure. I have a leaking cooling system manifold(?), on the back of the engine near the cambelt, but it doesn't look like any of the cooling system parts in the RTA manual (to me anyway). Two outlets on top, but one is blanked off. One on the left.
2.2HDI C8 - can you see the VIN in this post still? Otherwise I'll go and find the V5. viewtopic.php?p=759416#p759416
I suspect it's NFP and I might have to find a second hand one - bonus points if you can tell me if the same part was used on the 2.0HDI, please?
Thank you very much, Paul
Paul
I would have more Citroens if I had the space...
x 6945
mickthemaverick wrote: 25 Jul 2024, 07:36 Morning and not urgent. Could you please tell me what is missing in the bottom of my central armrest on the C4 VTR+. When you lift the lid and look down there is no floor but there is the end of a cable with a blue 12 pin connector laying loose in the bottom. Curious to know what is missing and the part number for it? Thanks :)
There are 2 diagrams for the centre console. Let me know 'A' or 'B' and the item number Mick.
A Front ConsoleB Rear Console
x 1489
Paul
Yes, can still see VIN. You are right it is NFP:
It is also used on the 2.0 engine in the C8, Synergie and Dispatch 1 and 2
x 8123
Hi Marc, It is the main box lining in diagram B, item 5 and possibly the insert item 6. Here is what it looks like:
The armrest
The armrest
Underside of lid
Underside of lid
The inside of the casing as it is
The 12 pin connector which I don't know its purpose
nomad123
x 6
Unread post by nomad123 »
Hello!
I need part number for engine Valve tappets and Timing chain tensioner kit ( maybe this part number 0849.23? )
Thanks!
tearing hair out
x 19
Thank you very much Richard.
Paul
x 1489
nomad123 wrote: 25 Jul 2024, 13:50
Hello!
Thanks!
Timing chain kit is 0849.23 (£243.70 in UK):
Tappets are 094288 (£31.50 each in UK)
x 6945
mickthemaverick wrote: 25 Jul 2024, 13:08 Hi Marc, It is the main box lining in diagram B, item 5 and possibly the insert item 6. Here is what it looks like:
Ok, so you don't have item (6), so that leaves (5) which is the STORAGE COMPARTMENT
FXT- - BLACK CORNELIE, part: 7589N9, £64.82.
Not sure what the 12 pin connection is for - it is on the central wiring though:
Have a look in your handbook to see if there's anything there that it could belong to.
The only thing I can think of is it may be for a 'connecting box' that has a Jack and USB port.
x 8123
Thanks Marc, when you say I don't have item 6, do you mean it's missing in my photos or it wasn't fitted to my car? :)
x 6945
Not fitted to your specific vehicle.
